Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-31-2009, 05:30 PM
alarche alarche is offline
1996 eclipse gst MT - no spark to cyl #2 and #3
Hi, everyone and thanks for your help!!
Here is the problem:
I got a code P0300- multiple cylinder misfire
Things done to car:
1-changed spark plugs and wires
2-got new ignition coil (for cylinders 2 and 3)
3-checked compression- about 175 psi across the board
Question:
I am not getting any spark into cylinder #2 and #3 from coils, but yes into #1 and #4.
I do get power from ignition coil connector (female end). How do i check if it is the (male end) connector of the ignition coil connector? I am thinking this is the problem, since i do get power and cylinders #1 and #3 are firing. Also, could it be the ignition power transistor? How do I check that?
any help is much appreciated!!
Old 07-07-2009, 02:11 AM
90smallblockgst 90smallblockgst is offline
Re: 1996 eclipse gst MT - no spark to cyl #2 and #3
i wasn't getting spark on #2 & #3 either i figured it out it was my cam positioning sensor it was crack so check that out. i also changed the wires coil's compression test and so much more and come to find out a new cam gear and a sensor fixed the problem.
Old 07-07-2009, 06:14 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Welcome to AF.
I would recommend you investing in a shop manual. They are cheap and will help you out a lot. It will show you how to test the power transistor and the cam sensor.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Tags
ignition coil , multiple misfire
