Old 04-05-2004, 12:26 PM
nathanmontez nathanmontez is offline
Angry Multiple codes
Hi Guys,
I'm new here and having some problems......
I have a 97 Chevy Silverado Ext Cab 2WD 305 V8 Stock
Right now I'm getting 4 seperate error codes.
306 misfire #6
I replaced the distributor, rotor, wires, & plugs
it is not running as rough now but the error code is still coming up???
117 engine coolant temp circ low
going to buy a coolant temp sensor..will see how that works.
507 idle control rpm high
I have no idea??!?!?!
1406 Mfg control Aux Emission
Also no idea???!?!?
I've been researching these problems for the last 4 weeks online so any help is appreciated thanks!
Old 04-05-2004, 06:16 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Multiple codes
the P1406 is related to the egr pintle position most of the time it's due to carbon build up, try removing it and cleaning it. check for vacuum leaks at all the lines and around the intake and proper operation of the IAC(idle air controller) for the idle problem. the #6 misfire might be a dirty injector. a bad coolant temp sensor will affect millage and driveability so you'll wanna swap that out right away make sure the connectors in good shape too.
good luck
Old 04-06-2004, 07:42 AM
thanks for the reply appreciate it!
92 Geo Tracker Multiple Codes Cam7 Tracker 0 07-01-2007 02:46 AM
Outback wagon with multiple codes... sbiddle Outback 1 05-26-2007 08:02 PM
Grand Voyager Multiples Codes, Help! Jare Caravan | Voyager 1 11-19-2006 02:49 AM
89 suburban has multiple codes, help requested. 9396 ULTRA Suburban 3 11-05-2006 02:31 PM
Multiple Codes - Cannot determine problem balewisca Problem Diagnosis 1 10-19-2006 12:12 AM
