Old 06-01-2003, 03:24 PM
nicks91civicsi nicks91civicsi is offline
Unhappy Tranny Help PLEASE
aright heres the deal...
iv got a 91 civic si with a zc motor swap. i used my 91 si tranny with the zc motor and it worked fine as i was told it would. i blew my tranny a couple of weeks ago and i ordered a used one from a place that imports japanese engines and tranns. the one i got had 20 spline and the one i took out had 21. or other way around. i used a 86-89 accord clutch disk cuz i was told it would fit and it did. now the problem is that with this new tranny its like my car has no power. it bogs starting up in first and shifting into second is like goin from 1st to third and the gears seam to be way longer than my old tranny. i also have another tranny from an 88 civic si which has the same # of splines as the one i have in my car now, that i cant mount. so im wonderin if maybe the tranny i have in is an 88 also and if the zc is not compatible with the tranny because of some differences in the tranny. anyways if anyone has any useful information or advise please help.
side note: supposedly this other tranny is from an 88 civic si..i bought it from a guy on another board and i didnt notice till after that it had 2 stripped holes and one with a broken off bolt inside where the mount goes so i cant put it in. so might not even be an 88 civic si tranny...
Cliff notes: does a 88 civic si tranny have a diff number of splines than a 91? and is it compatible with a zc motor?
Old 06-01-2003, 03:50 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
88 = 21 splines on the imput shaft
89-91 = 20 splines on the imput shaft
Most 88-91 Civic/CRX trannies say L3 on them so its sort of hard to know what exactly the tranny is due to lack of any info we know to look up the number and see what it was.
As for clutches I have an 88 ZC Tranny and I used a 88 CRX Si clutch and it worked fine.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-01-2003, 10:48 PM
thanks for feedback...does anyone know if theres a diff in between the 88 and 91 trannys? is one geared lower than the other?
Old 06-01-2003, 10:54 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
d16a.com
that will help you identify the trans. I believe 88 and 89 had 20 splines and 90-91 had 21.
There's nary an animal alive that can outrun a greased Scotsman!
Old 06-01-2003, 11:49 PM
91civicDXdude's Avatar
http://www.d16a.com/d_series_trannys.htm
very good direct link. check it out.
My tranny is locked/jammed, I can't shift it out of gear. Help please! danm1985 Engineering/ Technical 2 08-23-2009 11:36 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
89Z TH125 TRanny Help PLease!!!! Dr. Frankenstein Cavalier 4 08-02-2005 08:07 AM
engines and trannies help please 666_speed Camaro Discussions 6 06-13-2005 07:26 PM
Tranny Help Please trulyshavedintegra Integra 3 04-07-2005 07:19 PM
