Old 07-16-2009, 01:30 AM
danm1985 danm1985 is offline
Angry My tranny is locked/jammed, I can't shift it out of gear. Help please!
My 91 dodge spirit only has 40xxxx mi on it, and i came home after work today, and i couldnt shift it into park. (auto trans) Its so weird, it is completely jammed, i can't move the shifter. Please give me some pointers as what it might be o i can try to fix it tomorrow. I have lots of car experience, but I have never dealt with trannies before. Thanks!
Old 07-16-2009, 09:25 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: My tranny is locked/jammed, I can't shift it out of gear. Help please!
You mean you can't shift out of park or in park? If you are out of park, can you move it to other gears?
On an auto trans, park mechanism and other gears, are 2 different mechanism.
Park mechanism involve a mechanical cable connected directly to the park mechanism of the trans. Many things cause the park to stay locked. I may gave you more info on that later. It's very complicated.
Other gear change (R,N,D,3,2,1) involve another cable connected to a "transmission range sensor" (TRS). It's a switch that control the transmission electronically. Novaday, since 1988, alsmost all trans are electronically controlled. If this trans sensor is rusty, the shifter selector may be very hard to move. So gave more details on your problem.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 08-23-2009, 11:36 PM
waycool9's Avatar
waycool9 waycool9 is offline
Technician/ Designer
its probibly your shifter interlock thats stuck or jammed, its usually part of the shifter itself, sometimes accessible when you remove the handle, if its electrical try disconnection the battery turning the key on and pulling it out of park, then put it in neutral and it should start,
Tags
jammed , locked , tranny , transmission
