Old 12-05-2011, 11:31 AM
Ami Ami is offline
Unhappy 1998 escort leaking gas
i have a 1998 escort se when i park the car on a slant it leaks gas it has been leaking for about 2 weeks now. The other day i parked it on driveway it is up hill the car would not start so i push it down to a straight surface it started now i see the car is stalling now
could it be fuel pump
gas tank
or something else
Old 01-31-2012, 12:17 PM
CheapRudy CheapRudy is offline
Re: 1998 escort leaking gas
I have a 95 that did the leaky deal too. Mine would only leak a small amount if you filled the tank to full. Under a half tank and all was well. The biggest problem I had was that when full it smelled like gas should have been pouring out. Very strong smell. It really leaked more when pumpimg in gas at the pumps. My problem was the flex hose that connects the metal filler to the gas tank itself. Mine was a pain to find, as it was listed as a dealer part. Each end of the hose was a different diameter. I did find one on the 'net but don't remember the site. Might give it a look.
Old 02-24-2012, 08:33 AM
zzyzzx2 zzyzzx2 is offline
If it's anything like the older Escorts, you probably need one of these:
http://www.feoa.net/modules.php?name...wtopic&t=69872
Old 02-26-2012, 03:07 PM
electro452 electro452 is offline
My 96 was leaking gas also. I found the rubber gas hose that connects the tank to the filler nozzle was worn and cranked. I took it off and found one at autozone...
Ranger 1998 roof leak markdpro Ranger | Courier 1 04-24-2010 03:18 PM
gas to flex 98 gc sport TAGer98 Caravan | Voyager 1 12-22-2009 02:14 PM
Leaking Gas - Box in front of gas tank McShaken Venture 4 07-02-2006 10:03 PM
1998 escort wagon leaks redfearngeo Escort 1 10-08-2005 07:10 AM
1998 Monte Carlo LS Leaking Gas genomanx Monte Carlo 2 09-17-2004 10:51 AM
