Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-29-2011, 08:37 PM
TZ250 TZ250 is offline
Cold Air When Idling
Guys,
What would cause my heater to blow cool air when idling, but warm/hot air when driving?
I'm baffled.
Thanks in advance.
Old 11-29-2011, 10:06 PM
Tech II Tech II is offline
Re: Cold Air When Idling
Well, it sounds like a vac problem....but the way you describe it, is the opposite of what I would expect...if your temp valve is vac operated, and the check valve to the vac tank is bad, you would lose vac at open throttle, and would gain vac again at closed throttle......
Old 11-29-2011, 11:46 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Have you checked your coolant level ? That can cause the scenario you have described .
" Sometimes I grow so tired "
Old 11-30-2011, 09:58 AM
What is your temp gage doing?
Old 12-04-2011, 10:56 AM
Blue Bowtie's Avatar
Registered Offender
Is the water pump impeller eroded? I've seen that more than once.
2003 T&C, freq. refill coolant d/t cold air when heater is running DrPowercat Caravan | Voyager 3 02-11-2011 12:15 PM
Heater blows cold air when coming to a stop. bigkane01 G6 1 12-15-2010 01:31 PM
1992 S-10 2.8L V6 Idle Craziness DaleReynolds24 S-10 6 02-22-2010 10:13 AM
96 blows cold air when stopped jsimmoms Windstar 7 10-18-2005 05:16 PM
to cold for cold air?? anthony90si '88 - '91 Civic | CRX | Wagon | Shuttlee 6 10-22-2004 06:40 PM
