Old 10-09-2005, 05:11 PM
jsimmoms jsimmoms is offline
96 blows cold air when stopped
My Windstar will blow cool air from heater when stopped. I have replaced thremostat, radiator cap. Last year replaced water pump and that screwed up metal tube going to the lower radiator hose. Any ideas?
Old 10-09-2005, 05:27 PM
ruggratt ruggratt is offline
Re: 96 blows cold air when stopped
Can you clarify some? Do you mean that it blows cold air when the van is stopped (but with the engine running I assume, like sitting at a stop sign) , or do you mean that it blows cold air when the heater motor control is in the stop position? In any case, does it ever blow hot air? If so under what conditions?
Old 10-10-2005, 05:38 PM
Just when stopped at light.
Old 10-10-2005, 06:17 PM
Re: Re: 96 blows cold air when stopped
Well my first guess would be a partially clogged heater core. Have you flushed the coolant system since you made all the repairs? Check to see that when the vehicle is warmed up that the heater core area is getting hot. If you can't get to the heater core from inside try to see if you can reach the hoses on the firewall that lead to the heater core. If only one is hot then your core is blocked.
Old 10-11-2005, 11:53 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
What about traped air in the system? Just a thought from a far.
Regards
Dan
Old 10-12-2005, 06:16 AM
denisb denisb is offline
I tend to agree with Ruggratt. The Taurus (which is a Windstar under cover) is notorious for heater cores getting clogged. Easy enough fix. Disconect the coolant pipes at the firewall and flush with a garden hose in both directions.
Denis
Old 10-13-2005, 06:52 PM
Denis
That seemed to do the trick. Thanks for all the help.
James
Old 10-18-2005, 05:16 PM
wiswind wiswind is offline
FORD has a TSB out that states that you should do just that whenever you flush the cooling system......If you do not disconnect the heater lines and do the heater core separately, you run the chance of clogging the heater core.
