Old 02-10-2011, 07:09 PM
DrPowercat DrPowercat is offline
2003 T&C, freq. refill coolant d/t cold air when heater is running
I have to intermittently refill coolant reservoir in the van when the heater is blowing cold air. This solves the problem for a little while.
I obviously have a coolant leak, but cannot find any evidence on the ground under the car and do not see any obvious leak. Is this a heater core problem or is there somewhere the coolant is leaking that I am not aware of?
Old 02-10-2011, 10:22 PM
joeslip joeslip is offline
Re: 2003 T&C, freq. refill coolant d/t cold air when heater is running
probably have a head gasket leak and you are burning it in one of the cylinders
The Following User Says Thank You to joeslip For This Useful Post:
DrPowercat (02-11-2011)
Old 02-11-2011, 10:05 AM
That matches with what another person told me. I am going to take it in and have a pro look at it, but can you give me a ballpark of what that might cost? Doesn't sound cheap.
Old 02-11-2011, 12:15 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Could head to an Autozone or the like, sign out or buy ($30) a coolant systems pressure tester and find the leak yourself.
A pro is going to charge you $60 - $100 to troubleshoot then add the cost of the fix which could cost $50 - $800 depending on what is leaking.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Tags
coolant , heater
