Old 11-22-2011, 12:03 PM
hawkeye260 hawkeye260 is offline
P0336 crankshaft sensor code issues
I have a 98 5.7L chevy that shuts off while driving down the road. will not start unless I wait 5-10 minutes. code P0336 crankshaft position sensor "A" circuit Range/Performance. I have amateur mechanical abilities such as changing brakes, fuel pump, alternators and such. Wondering if this is something worth tackling or take to garage. I have read where there is no crankshaft sensor that it is in the distributor but also found online auto parts dealer selling one with 8th digit Vin "R" which is mine. Any ideas on a fix? It does seem to miss while accelerating at times. thanks
Old 11-22-2011, 05:46 PM
777stickman 777stickman is offline
Re: P0336 crankshaft sensor code issues
Welcome to AF: I'll try to answer your ?'s as best I can.
#1. Yes there is a Crank Position Sensor (CKP). It is located on the lower pass side of the timing chain cover on the front of the motor.
#2. The sensor in the dist is the Cam Position Sensor (CMP).
#3. P0336 is all about the CKP and has 18 diagnostic steps. Most have to deal with checking wiring and connections making sure there are no broken or shorted wires and all connections are tight and secure. Next check that the CKP is tight and secure in the timing chain cover.
#4. If it comes down to replacing the CKP you will need to do a "CKP Variation Relearn" which needs a high end scan tool in the hands of a competent technician.
Hope this helps you.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
hawkeye260 (11-23-2011)
Speed Sensor Code Issue tokie856 '94 - '01 2 09-15-2012 02:46 PM
Crankshaft Sensor? PCM? Camshaft Sensor? elninoeso Ram Van 14 06-10-2009 12:19 AM
Crankshaft Sensor Code/Engine Didn't Start jackie-boy 3 Series 3 04-21-2009 10:19 AM
crankshaft position sensor code kuchick Montana/Montana SV6 2 01-08-2009 05:17 PM
Crankshaft Positioning Sensor Code [Resolved....stupid mechanic] GirlBear Blazer 20 10-14-2006 11:54 AM
