Old 10-04-2006, 08:09 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Crankshaft Positioning Sensor Code [Resolved....stupid mechanic]
Inspection time is here again. Did a total tune up brakes, Tires, MAF, Oil, Plugs-Wires, Zerks. Hook up to portable cpu at local shop. Crankshaft Positioning Sensor Code. The Mechanic gives me a limited amount of info. Like yes its definately whats wrong. We cleared it and then cycled some miles thru it. And the SES light came back on. And it read same thing. I have a clue where its located. But not sure. I'm thinkin its a fairly mild procedure. But again im not a 100% on the details. Can anyone Hit me up with some info. Such as location and difficulty of said a project.
http://jowulf.deviantart.com/
Old 10-04-2006, 08:32 PM
alblogg's Avatar
alblogg alblogg is offline
Re: Crankshaft Positioning Sensor Code
what year Blazer?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-04-2006, 08:51 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Pretty simple job. Pull off the the front shroud, and right on the timing chain cover, at the bottom, behind the harmonic balancer, on the passenger side, you will see it. It is held in place by either a 10mil, or 8 mil little bolt. Unplug it and pull it out, reinstall the new one, clear codes and you should be good to go.
Old 10-04-2006, 09:16 PM
alblogg's Avatar
Heres what you are looking for.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-05-2006, 10:21 AM
534BC 534BC is offline
What does the sensor sense to determine crank position?
Old 10-05-2006, 02:49 PM
GirlBear's Avatar
Originally Posted by alblogg
what year Blazer?
1996
Man winter is right around the corner again. How Depressing.
Old 10-05-2006, 09:07 PM
herkyhawki herkyhawki is offline
Thr reluctor wheel is on the end of the crankshaft. The crank position sensor sends pulses to the ecm when the crankshaft spins past the sensor.
Old 10-05-2006, 09:54 PM
alblogg's Avatar
Originally Posted by GirlBear
1996
Yeah dummie me sorta figured out the year span of your Blazer after I looked at the picture.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-07-2006, 12:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
GirlBear
Ask him for the code no. and post it back.
And remember a code does not always say replace the sensor.
It says check it out first.
If it was a code P1345 the dist is not set right.
MT
MT
Old 10-09-2006, 08:29 PM
GirlBear's Avatar
I'd just like 2 extend a thank-you 2 you guys for helping me once again. people who r unaware of this site think im the 1 with all the knowledge. "crank sensor? wtf? kelly you should be a mechanic". took about 5 minutes to replace. again thanks
Old 10-11-2006, 03:07 PM
GirlBear's Avatar
Not all mechanics are Honest
Hello every1. Recently I posted a question in reguards 2 location of the "CRANK"shaft position sensor. I capped and Quoted Crank because I specifically asked my Not so Honest Mechanic the diffy between Both Cam and Crank Shaft Sensors. I tripple checked if I needed 1 or the other. He Told me it was "CRANK" not "CAM". I reset the Damned cpu. cycled a bunch-o-miles. turned off the blazer. restarted it and bingo SES appeared. I then went back to said Garage explained my situation. And recieved this response, "Well I told ya $70/hr we'll fix'er up for ya".
SON OF A BITCH!!!!
So can some one tell me Where is the Camshaft position sensor . And how do I go about Changing it.
Basicaly They figured I was a dumb chick that woul just have them do the work. When I explained I'd do it myself they gave me the wrong info.
Old 10-11-2006, 05:15 PM
alblogg's Avatar
Camshaft sensor is in your distributor. This is what you are looking for.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-11-2006, 06:18 PM
MT-2500's Avatar
AF - Advisor
Re: Not all mechanics are Honest
SON OF A BITCH!!!!
GirlBear
We need the code no.
Some parts places like autozone will read codes for free.
Just do not let them tell you how to fix it,
Just get code and post it back.
If the code is 1345.
It may not a cam or a crank sensor code.
It may be a code telling you dist is not set right.
Check the cam retard setting.
If over -3 or +3 cam retard you will need to reset the dist.
But you will need a scanner to check and set it.
MT
Tips on finding a good mechanic.
Check around Ask around
Word of mouth.
Family friends coworkers neighbors business people and delivery people.
Mailmen and parcel delivery people get around and notice a lot of stuff.
Even a good parts house knows what shops are good and not good.
Chamber of commerce and better business bureau and city hall.
If you find a good referral to a repair shop go look them over and talk to them.
Look for a clean looking busy place with nice people running it.
Ask a few questions and ask about their qualifications and training.
Not all places have trained tech/mechanics.
If they do not find a place that does.
Even all dealers do not have all trained techs/mechanics.
MT
Old 10-11-2006, 10:36 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
If it is the crankshaft sensor, then the sensor in under the front of the truck and you will see the sensor near the front crank pulley.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-12-2006, 07:01 PM
GirlBear's Avatar
A friend of mine climbed up into the engine compartment felt around the distributor. And wouldnt ya kno, the Camshaft sensor was UNPLUGGED!!!. He plugged it in I reset the cpu. Cycled some miles thru it. Turned it off waited a 1min. SES stayed off. gonna kiss the sky. so releaved. NYS Inspection here I come. On a downer The last person to touch the distributor was my mechanic. Thinkin he never replugged it back in. Also he was gonna charge me to diagnose it and fix it. Dishonest bastard!!!
