Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 11-16-2004, 02:34 PM
tokie856 tokie856 is offline
Speed Sensor Code Issue
Recently repaired a salvaged 2001 A4 quattro 1.8L turbo 5spd sedan that was hit in the front passenger side. All damage was isolated to that area. After repairing all damage and reseting the codes I have one code that will not clear.
The code is an ABS code #287 - speed sensor rear right-G44: "Open short circuit to positive".
Could anyone shed some light on what the possibilities may be causing this trouble code and possibly how to address it.
Thanks.
Old 04-21-2006, 02:33 PM
tmaster1187 tmaster1187 is offline
Send a message via Yahoo to tmaster1187
Re: Speed Sensor Code Issue
Had the same problem on a Chevy Silverado. The sensors in the hob sometimes go bad or need cleaning. There is a little metal(can't remember if the metal is magnetic or not) that reads how fast the sprokets inside the hubs rotate past it. If you are not getting any kickback in the brake petal it might just need cleaned, espically from where it probobly sat still(being wrecked) before you bought it. If you are getting kick back then the sensor might be bad alltogether. If you clean and/or replace in and it still does it then the abs "brain" is bad and you might have to replace it. Not sure on prices or ease of access to the sensor.
Old 09-15-2012, 02:46 PM
stuemany stuemany is offline
rust between hub and sensor is big problem
