Old 11-12-2011, 11:27 AM
jxg jxg is offline
2000 Caravan Resistor
Does anyone know where the blower resistor is located i have searched all over the passenger side under the dash board. I even opened the blower cover where the blower is housed but no luck. Other videos of how to replace the resistor such as on you tube, show you how too, but only on 2002 or other years but none are the same console as my wife's 2000 dodge caravan SE has anyone ever changed one or knows where it is specifically located!
Old 11-12-2011, 01:34 PM
jdl jdl is offline
Re: 2000 Caravan Resistor
My info says the resistor block is under the hood, passenger side firewall.
Old 11-12-2011, 03:20 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Found this long thread in a 20 second search. 1996-2000 are all 3rd generation Caravans. It's mounted on the engine compartment firewall high on the passenger side. Location changed with advent of 4th gen vans (2001-2007). It's on the front of the HVAC plenum inside the van. Includes pictures:
http://www.automotiveforums.com/vbul...d.php?t=340871
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-13-2011, 08:13 PM
b1lk1 b1lk1 is offline
You'll most likely need to change the pigtail/plug as well while you're in there. Caravans eat these parts like candy. While the fan motor will most likely still work, it is the cause of the failure usually as it draws too much power at lower speeds causing the resistor/wiring to overheat.
Old 02-20-2012, 07:50 AM
HeadlessHorseman1 HeadlessHorseman1 is offline
If the Resistor Block you replace doesn't give you at least 3 years of trouble-free service, consider replacing the Blower Motor AND the relay when your Resistor Block burns up next time. If the power pigtail is in bad shape, replace that too. Remember, you get what you pay for and, please pardon the cliches -- each of these components is a link in an electrical chain -- that chain is only as strong as its weakest link... been there, done that for 14 years and 300,000+ miles on my former GC/LE. You'll get what you pay for, and trouble for what you don't.
Like RIP said...
1999 dodge caravan resistor board for blower location kesystems Caravan | Voyager 11 06-26-2012 04:40 PM
location of ballast resistor 2000 caravan patarusky Caravan | Voyager 1 07-22-2009 04:27 PM
2000 durango...resistor location? Ice-man Durango 1 08-08-2006 10:48 AM
2000 Expedition Resistor Replacement Angella Expedition 6 03-06-2005 08:36 PM
