Old 07-22-2009, 12:51 AM
patarusky patarusky is offline
Smile location of ballast resistor 2000 caravan
Hello all! I need to know the location of the ballast resistor for the heat/A/C fan in front. I know on the 2002 I have it's right behind the glovebox. But there's not one there on the 2000. The fan just stopped working and all fuses and relays have been swapped out.None were bad. On my 2002 when the ballast went out I lost every speed but high. But I have no speeds at all. I'm going to run a hot from the battery to make sure it's not the fan motor but those ballast resistors are prone to fail. It is 9 years old after all. Thanks
Old 07-22-2009, 04:27 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: location of ballast resistor 2000 caravan
If you have the auto temp system you have a blower motor control module. It's one of those ugly little boxes with wires. Look in the same area as the blower motor resistor block.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
