Go Back   Automotive Forums Car Chat > Toyota > Sienna
Old 11-06-2011, 01:04 AM
dave2001auto dave2001auto is offline
Emission control EVAP canister hose connections
I was getting a P0442 (small leak) and when to a mechanic. He said I don't need to repair it immediately. Said the canister needs replacing $50 diagnosis charge). Estimate is $400 for the canister and $100 labor. Running a year witht eht check engine light. Then year later and SMOG check time now getting a P0441 , P0442 (small leak) and P0446.
The VSV for EVAP and for Pressure Switching test good. The VSV for canister is not holding vacuum when 9V battery is applied, so needs to be replaced. The The 2 hoses without the canisters hold vacuum with the engine side plugged.
The hoses on the canister are not connected as shown in the service manual. The air inlet port on canister (hose label #2 on my picture) is connected to the EVAP service Port/to VSV and manifold. The Purge port (next to the large vent line) is connected to hose #1 to the VSV at the air filter.
That doesn't agree with the manual.
Is the manual wrong or the hoses not properly connected.
I have a picture, but don't know how to attach it.
Here' s a link to the close up with labeled hoses:
http://s1213.photobucket.com/albums/...t=resized3.jpg
Whole canister and hoses picture:
http://i1213.photobucket.com/albums/...o/DSC05588.jpg
Old 11-06-2011, 05:41 PM
Re: Emission control EVAP canister hose connections
I sure that the hoses came that way from the factory cause there were different colored paint in the hoses and carbon canister and one of the hose would be short to connect the other line.
The VSV on the air cleaner is 90910-9030, but not in the current Toyota parts list. The TSB EG013-3 sep 29, 2003 has 90910-12209. Did not hold the vacuum hold test with VSV activated.
VSV on the canister is 90910-12264. Dorman makes are replacement 911-601, but the one I got was defective (leaked for pressure hole).
The line near the charcoal canister to the VSV for EVAP has a large bend, the places the tube below the first line. So the EVAP line appears to be the first line, but is actually the second in the series of 4 lines. Anybody else have this on their Toyota?
EVAP Canister Issues/Possible bypass? sk8injon Engine and Transmission 1 07-25-2009 08:39 AM
where is the evap canister or hose at on my integra ..please help cody3259 Integra 4 03-15-2008 08:55 PM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
EVAP canister purge volume control valve supertool Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 08-02-2004 02:30 PM
where exactly are Boost sensor and Evap. canister control valve? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 07-01-2002 02:31 PM
Tags
2003 , canister , evap , sienna , vsv
