Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-04-2002, 03:01 PM
raja raja is offline
Question Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor?
I took my 96 Maxima to Repair shop for Check Engine light on and they said these three parts (Evap. canister control valve, Boost sensor, and knock sensor) need to be replace. Gave me repair estimate for $900. I was just wondering how can all these three parts can go bad at the same time. Please give me some advice regarding fixing my car. Thanks
Raja
Old 06-04-2002, 09:53 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
they might good bad at the same time, but each car is different. how many miles are on the car ?
if you doubt anyone of the 3 things are the problm or the dealer is pulling your leg, you can check the codes yourself.
as for the parts you may find them in a junkyard and I think I have the Evap. canister control valve and Boost sensor, I've got to check.
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 06-05-2002, 10:52 AM
I just bought this car about a week ago and it has 80000 miles on it. I have already ordered the parts from Nissan Dealer. I will try to check the code and see if it gives me the same codes. Thanks for your reply.
Old 06-05-2002, 11:49 PM
GT-R MaX GT-R MaX is offline
did u go 2 the nissan dealer or a mom & pop shop?
Old 06-06-2002, 12:29 AM
MaxRX7's Avatar
Re: Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor?
yeah definately
Old 06-06-2002, 10:58 AM
I went to Auto Lab for code check. I checked the trouble codes yesterday and I got three codes. I didn't get a code for Boost Sensor but I did get codes for Knock sensor and Evap. canister control valve. The third code I got was for Evap. control System. I have no idea what exactly that is. You think I should replace Boost sensor even if I didn't get trouble code for that? Thanks for your reply.
Old 06-06-2002, 04:50 PM
MaxRX7's Avatar
nah, don't replace it. It should be find. see what the other do first, and if you still have a problem then examine the car some more.
if the car is fine, then just reset the ecu and you are set
Old 06-11-2002, 02:37 PM
Rotary Mech Rotary Mech is offline
got the same problem
i own a early 97 max and i have the same problem.
My check engine light lit up and i need a smog.
i went to my friends garage and he pluged in a mag scanner.
my car had 3 problems: PO325-Knock senor 1 - ckt malf.
PO440-evap control - sys malf.
PO446A-evap vewt - ctrl malf.
he then cleared the codes and the light went off with out reseting the ecu. i drove the car for a couple days and the light turned back on. it goes off sometime, but most of the time remains on.
How much you spend on parts?
Old 06-12-2002, 01:44 PM
I got the parts and repair shop said they are going to charge $400 just to replace the parts.
Evap. Canister control valve was for $60
Knock sensor was for $ 150.
I think you better replace the parts. Also use premium gasoline.
Old 06-13-2002, 03:16 AM
was it hard to replace.
where is the stuff located?
can you hook it up with some instructions and tips?
did you need to reset the computer?
I always use 91 octane gas, do you think those fuel injection cleaners will help? what about octane boosters?
thanks...
Old 06-13-2002, 10:21 AM
Repair shop people replaced the parts. It is not easy to replace knock sensor. I spent 2 days trying to replace it but couldn't do it. But I found somebody who replaced it for $200.
Old 06-13-2002, 10:25 AM
checkout the link below. It didn't work for me but It might work for you.
I couldn't find the Evap. Canister control valve.
http://www.skippynet.com/maxima/knocksensor.htm
Old 06-13-2002, 10:35 AM
More on knock sensor
http://www.automotiveforums.com/vbulletin/t42732.html
Old 06-13-2002, 04:09 PM
Lewtion1 Lewtion1 is offline
i got the same codes before....both of the evap ones. mine was covered under warranty though. the evap stuff is for the excess fumes coming off of your fuel. it controls the levels so that it doesn't become excessive to the point of dangerous. at least this is what i found out thru research before i got it done. if you don't get them fixed, your check engine light will stay on permanently.
Old 07-01-2002, 02:32 PM
I have replaced both parts and engline check light is gone. Thanks
EVAP Canister Issues/Possible bypass? sk8injon Engine and Transmission 1 07-25-2009 08:39 AM
code: 1655 EVAP canister purge valve luvmyS10 Beretta 7 01-21-2009 03:11 PM
Can't find EVAP Canister Vent Valve ('98) jkwiechert Prism 1 06-16-2008 01:51 AM
Canister Control Valve? What does it do? PeteA216 Caprice 7 11-26-2005 03:27 PM
where exactly are Boost sensor and Evap. canister control valve? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 07-01-2002 02:31 PM
