Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-15-2007, 01:25 AM
cody3259 cody3259 is offline
Smile where is the evap canister or hose at on my integra ..please help
I have a 1997 Acura Integra 1.8 liter non v-tec LS with a small problem my check E. light came on and I had autozone read it ... it came up as troubleshooting code po441 which says the pcm has determined that the purge flow in the evaporative emission control system is incorrect for the current engine operating conditions. Definition EVAP (Evaporative Emission System) small leak/no flow condition
Explantion
The evaporative emssion system is monitored
probale causes
1. Defective or loose fuel cap (I replaced the fuel cap with a new one and made sure I heard the clicks when I put it on and had the light turned off but it came back on to read the same code again)
2. EVAP Canister or hose cracked-not connected
3.purge or vent solenoid defective
what does all of this amount down to? Some please help me with this and give me some tips Thank you so much in advance
Old 08-20-2007, 10:26 PM
Re: where is the evap canister or hose at on my integra ..please help
someone that may could offer any kind of help please help me Thanks Cody
Old 03-01-2008, 06:57 PM
BlackTeg98 BlackTeg98 is offline
Send a message via AIM to BlackTeg98
i have a 98 integra. it sould be the same as mine and its like right below the fuel filter, like below the intake, you can see the evap box if you take off the intake tubing from the throttle body. u'll see the purge solenoid that is mounted to it. its hard to explain but i hope i made sense
<a href="http://enjukuracing.com/index.php?ref=18&affiliate_banner_id=5" target="_blank"><img src="http://enjukuracing.com/affiliate_show_banner.php?ref=18&affiliate_banner_ id=5" border="0" alt="EnjukuBanner2"></a>
Old 03-15-2008, 12:24 PM
needsomeinfo needsomeinfo is offline
i have the same problem but my car is a 2000...will an evap canister from a 98 work on a 2000???
Old 03-15-2008, 08:55 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
come on guys this thread is 7 months old
start a new one dont revive dead threads
