Old 11-02-2011, 08:40 PM
Tonyr's Avatar
Tonyr Tonyr is offline
both headlights just went out!
Headed to work this morning and noticed my lo beams were not working. The hi beams and parking lights do work. I pulled both bulbs out, put them in my dads truck and they worked just fine. Fuses pulled and are ok as well. Relay seems to be clicking and working. Could it be a multifunction switch? The display pops up and says that headlights are recommended...maybe some kind of sensor is shot.
Old 11-02-2011, 09:47 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: both headlights just went out!
What are you working on?
Old 11-03-2011, 08:47 AM
Tonyr's Avatar
Wasn't working on anything. I got in the car (2008) and was going to work in the morning and then noticed the headlights would not come on. The bulbs are good because i tried them in another vehicle. Brights work, turn signals work...I'm thinking the headlight switch must have went out. I have it at the shop this morning so I'm sure I'll wish I could have found an answer here first.
Old 11-03-2011, 09:07 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Looking forward to an update on how your shop visit goes!
Sarah
GM Customer Service
Old 11-03-2011, 05:23 PM
Tonyr's Avatar
It was the relay module. I should have just went and bought one at Auto Zone. Would have saved a lot of money. Was charged $50 for the relay and $62 for labor/shop parts. What a rip-off. That's why I hate going to a dealership.
Old 11-03-2011, 07:11 PM
Tech II Tech II is offline
What is your problem? Your car is fixed.....they diagnosed it and put it in and only charged you $62.....you should have done it yourself and put the headlight switch in like you wanted to....and then you probably would have found some way to blame the dealership for you putting in the wrong part....
Old 11-04-2011, 06:35 AM
doctorhrdware doctorhrdware is offline
He was going to replace the multifunction switch, the stealership replaced the relay that latches when you turn on the high beams. That would not have repaired the problem of having no low beams. But I could be mistaken? $50 dollars for a relay what a rip. That is why at all costs I stay away from the stealerships.
Old 11-05-2011, 08:36 AM
Tonyr's Avatar
Geesh...Just gave my honest opinion about the dealership or stealership (good one). They always charge way more than a regular shop. Guess I should quit "complaining" I should have known better than to take my car there again. It would have cost about 30% less easily if I would have stayed away from them like I will do in the future.
Old 11-06-2011, 05:43 PM
fishlipeater fishlipeater is offline
I have the exact same issue... glad I checked the forums here before I went to a mechanic
Headlights/Dashlights just went out?!? n2o4ever Engineering/ Technical 1 04-09-2007 03:36 PM
Temp backlight just went out Piepmeyer TrailBlazer | Trailblazer EXT 1 12-29-2006 03:04 PM
Interior door lights just went out... Help emperor_of_weasels Beetle - New/New Beetle Convertible 2 07-18-2005 02:14 PM
1986 Subaru XT 4x4 Turbo 1.8L - 4X4 Just went out!!! yksten General Discussion 1 03-28-2005 07:35 AM
Brakes just went out seldomseen Grand AM 1 12-15-2003 11:36 AM
