Old 10-23-2011, 09:25 PM
Christian06Dodge Christian06Dodge is offline
2001Buick wont start
My father has a 2001 Buick La Sabge anmd last spring it would start hard when it was cold it warmed up and stoped so My father thought it was the battery so he replaced the Battery well this fall when it got cold it started doing it aggain but now it ran rough untill it was warm then justr recently it turned into everytime u would stop it would stall out I took the airfilter out and put a new one in and it seemed to run good for a few days then it got even werse it has gotten to the point that my father could only go 15 and had the peddal to the floor and it was backfireing only the Misfire fuel and comprehensive componint monitors are in a ready status with no DTC's I will pull spark plug tomorrow and let you know whatI find any advice will be helpfull
Old 10-24-2011, 12:53 PM
Tech II Tech II is offline
Re: 2001Buick wont start
When the vehicle won't start, check fuel pressure, spark, and injector pulse...
Check the fuel pressure regulator vac line for fuel....
Try starting with the MAF disconnected...
Old 10-24-2011, 09:53 PM
I forgot to mention its not even engaging the starter a friend of mine suggested it jumped time dose anyone think he is correct and I did not get a chance to pull a spark plug
Old 10-25-2011, 10:17 AM
imidazol97 imidazol97 is offline
AF -Advisor
Does the starter turn over the engine?
Does the engine start running?
Old 10-25-2011, 09:09 PM
no all it dose is make a click kinda like when the starter goes but it is a little different
Old 10-26-2011, 08:26 AM
I guess we got the rest of the story....
Check the battery connections.......if ok(clean and tight, replace bolts if necessary), put a voltmeter across the battery(nothing on)...should read 12.6 volts......what do you read when key is in the crank position?
Should be at least 10.0 volts.....If over 10 volts, bad starter/connections at starter.....less than that, battery is dead....try jumping the battery or recharge it....
If it starts, check output of alternator with voltmeter when engine is warm...rev to 2000 rpms...should be over 13 volts....
If it is, check for a parasitic draw........
Old 10-26-2011, 09:28 PM
AF -Advisor
Check the ground connection at the floor pan. Remove and clean if necessary to be sure there a clean bright metal connection.
Have someone tap on the starter with a hammer, lightly, while the key is turned to crank. It could be the starter...
a good troubleshooting for the connections and the weak battery suggested in the previous post, is just connect a jumper cable from another good battery in a running car. If that provides the right power to start, then trouble shooting backwards toward the battery.
Old 10-27-2011, 06:31 PM
checked with my father its no starter that was just replaced in the past 3 months and Battery is good cause it was just replaced only other thing it could be is alternator how would I check that
Old 10-27-2011, 07:02 PM
The alternator is not used to crank a vehicle....
If you mean the starter was just replaced, doesn't mean that it can't be bad.....if the battery is good, and you have power to the "S" terminal of the starter with the key in the "crank" position, the starter is bad.....if you DON'T have power in the crank position, does the SECURITY light go out after 5 seconds when the key is just turned to the "run" position?
No, the battery could be dead if the vehicle has a parasitic draw OR if the alternmator was not charging the vehicle.....but if it wasn't charging, the RED BATTERY indicator would have been on while he was driving it....
Was a voltmenter put on the battery and tested like I asked? You can't check if the alternator is charging, unless the vehicle is running.....was the battery checked? Were the cable connections checked? Did you try to jump start the vehicle?
1991 wont start..motor from 1985 no spark HELP rwoodxtreme C/K 4 01-31-2010 10:19 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
97 yukon wont start yukon45427 Yukon 1 06-23-2009 07:24 AM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
03 Eclipse rs wont start mrcontreras Eclipse 2000+ 1 02-27-2009 05:49 PM
