Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-22-2011, 03:36 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Horn problem with CVPI 02
I have an ex CVPI 02 police car but with police package removed. So now it's a normal CVPI. The problem is that the horn is not working.
I already checked the fuse n°5 (15 amps) and relay n°2 and they're good.
The guy who sold me the car told me that 2 wires under the steering column that goes from the wheel switches have been disconnected because before there was an air-horn who has been removed.
So I want to know which color are these wires that connect the steering wheel switches?
I'm also interested to have a schematic of the horn. ARRC at EBSCO doesn't work anymore.
When I press on the switches buttons, I don't have 12V on the relay n°2 coil. Power only at one side of the coil, no return.
So it's really a problem with the 2 wires.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 10-24-2011, 07:07 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Horn problem with CVPI 02
Here is the short and sweet wiring. You might want to enlarge it a little.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-24-2011, 09:19 PM
Thanks for your schematic.
I'll check the 20 D6 connector.
Old 10-25-2011, 06:19 PM
Ok I just fix the problem. The blue wire from the 2x2 connector was cut. Actually there was 2 cutted blue wires. The both from the steering wheel were giving same GND signal when I press the horn buttons. So only one of them is enough. From the relay input section, only one of them were connected to the relay. It gaves 12V (through the relay coil). So I just connect one wire from any of the two wires from the wheel to the right one at the other end side.
I'm sure they're cut to plug an siren/air-horn module between the two wires extremity.
Also the horn connector at front bottom center of the radiator was not fully inserted. Now it works.
Old 05-28-2012, 05:57 PM
The second blue wire is connected to the BCM so when I press on the panic button of the keyless entry remote, the car make multiple horns.
So the 2 blues wires from wheel should be connected to the 2 blue wires that go in direction of under hood. The 2 wires from the wheel are already tied together. So all 4 wires are indirectly connected together.
Horn Problem... XeroInfinity ebreiner Grand AM 15 08-01-2013 11:12 AM
problems with cig lighter,fog lights, and horn amanda_carver Grand Prix 1 10-30-2008 07:10 AM
Problem with horn and sterring wheel. Need help urgent! sebaz LeSabre 5 01-22-2008 05:04 PM
s10 electrical problem with horn boss429 Problem Diagnosis 31 11-07-2007 08:32 AM
problem with horn on 2003 ZX3 zlarson Focus | C Max 1 06-10-2006 11:41 PM
