Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 10-15-2011, 08:54 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Right- front speaker
Hi Gang,
The right front speaker in mine doesn't play unless you crank in alotta volume then I have to bias the balance & fade to that particular speaker to even out the volume. That done, it plays without noise, jes' takes more power.
Anyone know a fix?
1992 Bravada, 190K, stock
1997 Bravada, 101K, stock...was "called away"
Old 10-16-2011, 11:09 AM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: Right- front speaker
You could try swapping it with the one on the other side to see if its the speaker or the amp, both are pretty cheap, if you want to go original amps are like $10 at the wrecking yard. Speakers are fine in ours but she wants me to replace the amp with one that has a port for her mp3 player, you can get a brand new one for under a hundred.
The Following User Says Thank You to ericn1300 For This Useful Post:
Chris Stewart (10-16-2011)
Old 10-16-2011, 07:38 PM
AF - Advisor
Thanks Eric,
Do the front speakers come out the top?
The left front and both rears are ok.
While we're talking sound, the AM stations seem like they're getting scratchy sounding.
I disconnected the antenna wire under the hood, re-connected and generally worked that connection with no improvement.
The FM stations are coming in fine.
Wasn't there a fine tune screw on earlier radios (but after the tube types)?
The brakes are getting seated in and real nice.
Old 10-17-2011, 05:44 PM
ericn1300's Avatar
AF Premium User
Scratchy sounds on the AM band are usually caused by RF interference from the ignition system, sounds like your spark plug wires are getting old and the insulation is cracking. As I remember from my youth, when cars only had AM radios, you could buy a power filter to eliminate the noise, and spark plug wires came labeled as low noise. Does the problem get worse as you rev the engine? Ignition interference usually increases with RPM's.
The fine tuning screw for the AM spectrum actually came into being in the digital age, the old dial tuners allowed you to fine tune the station, an art forever lost to our youth.
Old 10-20-2011, 08:42 PM
AF - Advisor
Did some more checking and found the passenger side rear speaker isn't playing at all.
Saturday morning I'll pull the door panel and see what's going on.
steering wheel shaking, pulling to the right uspres2020 Escort 6 10-10-2009 05:58 PM
No Power to Rear Right Speaker In '96 Cavalier Douglas91 Non-Performance 2 06-21-2009 09:10 PM
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 08:16 PM
Everythings ok except right rear speaker awpi Cavalier 0 02-23-2007 12:17 AM
98 camry air noise coming from right rear speaker moparmick Camry/Camry Hybrid/Vista 0 10-10-2004 09:11 PM
