Old 02-23-2007, 12:17 AM
awpi awpi is offline
Question Everythings ok except right rear speaker
I have a 94 chevrolet cavalier station/wagon. Recently changed the factory radio with Sony Xplod. I use wiring harness and i am 100% sure connected every wire correct (maybe 99%) .
Here is the wiring diagram that i used :
Left Front Spkr (-) White w/ Black Stripe
Left Front Spkr (+) White
Right Front Spkr (-) Gray w/ Black Stripe
Right Front Spkr (+) Gray
Ground Wire Black Black
+12 Volt Ignition Wire Red
+12 Volt Battery Wire Yellow
Right Rear Spkr (-) Purple w/ Black Stripe
Right Rear Spkr (+) Purple
Left Rear Spkr (-) Green w/ Black Stripe
Left Rear Spkr (+) Green
On wiring harness i have Black (Ground Wire), Orange (Headlight Dimmer Wire), Blue (Power Antenna) wires i taped individually.
Everything is working except right rear speaker and also i'm getting failure message on my sony deck when i turn it on (which means "the connection of speakers is incorrect).
My questions are ;
1) Do i have to connect to black wire from wiring harness and other black wire from deck together ? (I connected the black ground lead (from deck) to a metal surface of the car)
2) Does my car has an external amplifier ? If yes should i use blue power antenna wire from deck? How ?
I'd like to know my alternatives.
PS: The all speakers were working with my old radio.
Thank you for your time.
