Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 10-11-2011, 01:37 AM
vXv_crucial_vXv vXv_crucial_vXv is offline
Tempature Going Up And Down
I was on my way home from work tonight and the temperature gauge on my 2001 Dodge Neon R/T was going up and down. I am supposed to be back to work in 10 hours and was wondering if anyone knew what it was or what to check.
Old 12-07-2011, 11:38 AM
Chromehero Chromehero is offline
Re: Tempature Going Up And Down
You might start with the Temp Sensor. It is called something different now, but function is the same. It is on the Head of the engine on the Driver's side (at least it is on mine).
It should be cheap to get another one, but it is difficult to replace due to it's location.
If you are looking for faster/easier things to check: see if you are leaking coolant. Check your hoses. If the level is low, that could cause it to fluctuate wildly.
antenna not going up and down andyjs3589 Integra 4 01-30-2006 08:47 PM
? in park, rev up engine then it starts going up and down up and eaglescars Lumina 2 08-09-2005 11:41 AM
Revs go up and down will cold!! acehardy Prelude 8 02-12-2005 01:42 PM
99 TA lights go up and down and grind when I hit the keyless entry on keychain...help sixdog Camaro Discussions 2 10-25-2004 10:50 PM
Tags
2001 , dodge , neon , r/t
