Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-29-2006, 08:54 PM
andyjs3589's Avatar
andyjs3589 andyjs3589 is offline
Send a message via AIM to andyjs3589
antenna not going up and down
I have a 94 integra gsr and yesterday, the antenna stopped going up and down when i turn the radio on and off, it is stuck about 1/2 to 2/3 of the way up. Any suggestions on how to fix this or were to buy a replacement antenna assembly?
Old 01-30-2006, 12:43 AM
WReX WReX is offline
Re: antenna not going up and down
try spraying the antenna with some WD-40 or other lubricant and then see if it will go up and down
sometimes rust can form in there and stop it from working
26 PSI anyone?
Old 01-30-2006, 06:42 PM
andyjs3589's Avatar
this morning when i tried to turn the rear defroster on it did not work, do you think that it could be something electrically wrong with it like a blown fuse?
Old 01-30-2006, 06:58 PM
its most likely a fuse
26 PSI anyone?
Old 01-30-2006, 08:47 PM
andyjs3589's Avatar
i just replaced the burnt out fuse and it all works fine thanks for your help
