Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-05-2005, 09:18 AM
acehardy acehardy is offline
Revs go up and down will cold!!
When a little cold till temp goes to half revs goto 2000 for sec and revs down to 1000 goes this when stopped at a light. When car is warm at half temp stays at 1000. Please help
Old 02-05-2005, 10:39 AM
del del is offline
móddə rąytər
Re: Revs go up and down will cold!!
te hablas ingles????
anyway, if i understand what you're saying correctly, check your coolant level or for any coolant leaks.
Old 02-05-2005, 09:55 PM
ludeguy ludeguy is offline
check your IACV - take it off (two bolts) use a toothbrush with some carb cleaner and clean the little metal mesh screen - it has a tendancy to get some carbon desposits that can cause this. beyond that - there is also a chance that it could be your FITV (mounted underneath your throttle body) it has 3 bolts to take out in order to get it off - then you can remove a metal plate on the end of it (2 or 3 screws) there is a plastic fitting that sometimes backs off, and can cause a similar issue - just snug it back down (don't overtighten). - try the IACV thing first tho.
cheers and best of luck.
Old 02-06-2005, 07:54 PM
lorunner lorunner is offline
Another way is whith it surging is to remove the intake tube and cover the ports inside the throttle body if the idle returns to normal it indicates that the IAC is stuck open. Also may be a fast idel valve. Depending on the year of the car.
Stop asking me about radio codes I cant get them anymore!!!
Old 02-09-2005, 09:45 AM
3shadswhite 3shadswhite is offline
i bought a new idle air control valve and it made the problem worse, i have no idea what to do
-93' SI
Old 02-10-2005, 08:01 PM
Hi I tried that also didn't work but check the coolant (sounds simple i know) thats what a user said and yes it was low!!!! now runs like a dream!!! DUMBEST THING EVER
Old 02-12-2005, 01:10 AM
speedlude's Avatar
speedlude speedlude is offline
Send a message via MSN to speedlude
hey i had the same problem with my si the idle would go around 2000rpm then drop down to 100rpm sometimes conk out at the lights till i found the idle screw just above the intake on the throttle body i ajusted it and its been fine ever since.
Old 02-12-2005, 02:25 AM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
I have the same problem (if you'd call it a problem) with my prelude.
Searching through past posts helped, but trying to find a definite answer to the problem was almost impossible. The general consensus of people said that it is caused by a dirty IACV (idle air control valve) behind the throttle body.
My own theory, being that it only does it when cold, is that the thermostat sends the signal to the ECU that the coolant is not at proper operating temperature and the ECU ups the idle to heat up the coolant. On the next few cycles, the ECU sees that it's warm enough and lets the car idle down, becoming cool again.
Please correct me if i'm wrong, as this is just a theory. It would, however, be nice to get to the bottom of this cold-weather idle problem once and for all. Seems like some people give others the runaround and/or just recycles second hand information that doesn't seem to work for people in the first place.
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 02-12-2005, 01:42 PM
Hi I don't know about your theory but the coolant was the problem for me but my friend had the same problem and had the replace the main power assembly. $30 its a switch which solved his problem. I guess it veries as we have the same year and model lude.
