Old 10-25-2004, 10:29 PM
sixdog sixdog is offline
99 TA lights go up and down and grind when I hit the keyless entry on keychain...help
Old 10-25-2004, 10:40 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 99 TA lights go up and down and grind when I hit the keyless entry on keychain...help
You need to change your gear/gears to brass gears instead of the cheap gears which have already worn a couple of teeth and thats whats causing that noise do to the motor grinding the gear due to the teeth not locking up when its in the closed position. Easy fix and they sell the kit on ebay. Good luck and keep us posted
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-25-2004, 10:50 PM
chickenkicker's Avatar
chickenkicker chickenkicker is offline
Gears are stripped out, mine were grinding really bad. I replaced them with the Brass ones from http://www.bfranker.badz28.com/headlightfix/index.htm they are very high quailty and come with instructions and an install kit.
Black 97 Trans Am M6 - TB Bypass, !CAGS, Manual Fan Switch, 1LE Elbow, K&N FIPK, SLP Loudmouth Exhaust, cross drilled and slotted rotors.
Click here to visit my CarDomain page
