Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 10-09-2011, 07:15 PM
SmokinHero SmokinHero is offline
Heater core
I was wondering if someone could give me detailed way to change out the heater core in a 1992 buick skylark gran sport v6 3.3L. I can't find anything that explains how to do it. Please and Thank you.
Old 10-09-2011, 07:25 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Heater core
Pretty easy- drop the a/c condensate drain pan and it is right behind there--you have to remove some air ducts and the hush panels above each footwell. remove the several 5.5mm screws around the drain pan--and take off the drain pan elbow off the engine side of the firewall- pull drain pan straight down in back to avoid cracking it. Heater core is in behind a temp door cover that has only two 5.5 mm screws holding it in. The plastic pipes on those heater cores tend to break and leak-- getting the heater hoses off from the engine side may be the hardest part....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-09-2011, 07:44 PM
Re: Heater core
alright thanks, should i follow this?
http://ww2.justanswer.com/uploads/mo..._141915_hc.pdf
I got from searching google but just wanting other people to help explain.
forget got to say, im nt really good with car's im still learning while fixing my buick up
Heater Core Help emmaandleesmom SC/SL/SW 3 04-01-2010 11:43 AM
2002 Saturn L 300 heater core replacement Dadsvan LS/LW 0 03-22-2010 11:17 AM
97 k1500 z71 silverado, BLOW THE HEATER CORE???? kokopelli85 Silverado 6 01-12-2010 07:38 PM
1998 ACHIEVA Heater Core darkflame64 Achieva 1 12-31-2009 03:05 PM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
