Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 10-08-2011, 07:45 PM
Wr_guy Wr_guy is offline
lose Vacuum hose and heater control not working '00 Venture
I have an "extra" vacuum hose comming off the back of the intake manifold on the passenger side.
It has a few 90 deg fittings on it and it is about 2 ft long before it is broken off at mid line. I cannot figure out where it goes.
Meantime, I also have an inoperative heater box control that works on vacuum. Turn the dial and nothing changes.
Could they be related?
Can you tell me where the vacuum tank is and how the vacuum gets to the heater control?
Thanks
Old 10-10-2011, 05:31 AM
sverker sverker is offline
Re: lose Vacuum hose and heater control not working '00 Venture
Yes, it's related. The hose goes from the right back side of the upper mainfold to a split which is located behind the battery so search for a loose end in that region. It happened to me that the hose got in connection with the serpentine belt.
Old 10-12-2011, 11:34 AM
Thanks. the busted end of the vacuum hose was buried in the wire loom.
I spiced it back on....but the heater control still is limp.
any ideas of the vacuum source for the heater control?
Old 10-12-2011, 03:14 PM
That is the vacuum source for the heater control. You need to check that you don't have any leeks, other loose ends or clogged lines.
2003 Heater Control not working or no power to it comet240 General Discussions 4 01-24-2013 07:54 AM
93 GMC Sierra Digital Heater Controls Not Working boosted3 Sierra 2 01-13-2007 01:57 PM
Heater control not working on low homerr General Discussions 3 03-06-2006 07:01 AM
FIXED! AC Stuck on, Heater Controls not working, Hissing noise Nitrate S-10 2 04-19-2005 07:52 AM
heater control not working superXracing Sebring | Sebring Coupe | Convertible 1 11-14-2004 06:47 PM
