Old 09-26-2011, 01:51 PM
trailblazer05help trailblazer05help is offline
trailblazer will not turn off
Hi I have an 05 chevy trailblazer, it will not turn off. You can turn ignition switch to off, pull key out. It is still running takes a couple of times turning on to off most of the time. Did replace the ignition switch still does it. Checked relay with new one, nothing changed.
Old 09-26-2011, 02:06 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: trailblazer will not turn off
When you say you changed the 'ignition switch' are you refering to the actual switch itself...underneath the dash board or are you referring to where you insert the key into the steering column?
Just wondering because alot of people get them confused.
Old 09-26-2011, 02:11 PM
it is on top of the column
Old 09-26-2011, 02:16 PM
Tony Silva's Avatar
on top of the column near the steering wheel or on top of the column behind the dash board?
Old 09-26-2011, 02:26 PM
not under dash but it only does it when you drive it for a while about 30 mins, it pulled 2 codes on p1682 cant remember other one but it was for if you push tthe gas nothing happened said to change ignition switch. after changing switch gas is working sounded like relay, relay might stick(sounded like it) it would click and then something on trans would click and sounded like brakes tightening????? sorry make any sense
Old 09-26-2011, 03:24 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Sounds like things that happen after my wifehas been driving it.
As asked did you replace electrical switch or just key and tumbler.
We need both code no.
On code 1682 there is a tsb on it.
That refers to checking for low battery voltage that could set that code.
A low battery or battery voltage can dosome strange things.
Confirm good battery and voltsge.
MT
battery voltage gauge at 0, inside fan blower will not turn off, temp gauges off pilaf153 Thunderbird 4 12-11-2006 06:09 PM
94 Altima brake lights will NOT turn off! Hybrid93Hatch Altima 6 10-08-2005 01:23 PM
heater blower will not turn off ,key off elmocrab LeSabre 8 11-05-2004 01:02 PM
Please advise, BRAKE light will not turn off! TJKirby82CE Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 10 12-25-2003 06:28 AM
cooling fan will not turn off ewgoodie Escort 1 07-23-2003 03:52 PM
