Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 07-08-2003, 09:00 PM
Hybrid93Hatch Hybrid93Hatch is offline
Send a message via AIM to Hybrid93Hatch
94 Altima brake lights will NOT turn off!
Any ideas? The car has been fine. Moved it to another parking here at the apartment and the brake lights will NOT shut off now. The lights were not turned on when moving the car. I tried messing with the brake pedal, e-brake, pulled the tail lamp fuse and reinstalled --> lights still on.
For now the fuse is pulled. Any ideas?
The license plate lights are not on. Just the 3rd brake light and the 2 tails.
Thanks!
2005 TCM Scion xB
Old 07-08-2003, 10:37 PM
Nissan Sales 310's Avatar
Nissan Sales 310 Nissan Sales 310 is offline
Send a message via AIM to Nissan Sales 310
that is crazy i will ask at work tommorow and try to get back with you
Robert
Old 07-09-2003, 06:43 AM
Thanks! They are still on as of this morning when I plugged the fuse back in.
2005 TCM Scion xB
Old 06-25-2004, 09:39 PM
khamm khamm is offline
Re: 94 Altima brake lights will NOT turn off!
Was there a mysterious chunk of broken plastic on the floor? They used rubber plugs on the brake pedalassy where the switches contact the upper pedal. They dry-rot , break, and then you have a dead battery. Just replace them with a generic plug so the switch makes contact.
Old 10-08-2005, 12:05 PM
mike171562 mike171562 is offline
Im having the same problem, the brake lights stay on even when the switch is removed. what could it be?
Old 10-08-2005, 12:53 PM
Re: Re: 94 Altima brake lights will NOT turn off!
Yes, that was the problem....
Turned out a little plastic piece broke off and had to reglue a fabricated plastic piece in it's place..... Just look down at the brake assembly.
2005 TCM Scion xB
Old 10-08-2005, 01:23 PM
Re: Re: Re: 94 Altima brake lights will NOT turn off!
i just fixed it, turns out that was the problem, there are two switches though, the other one is hard to see, thanks everyone
