heater blower will not turn off ,key off
I believe the problem is the heater module, but can someone tell me where it is located, the part number,or anything else that may help me.
J.R. |
Re: heater blower will not turn off ,key off
do not know what year,two location,one under hood behind max fuse box,the other under dash on right side
michel |
1997 Buick lesabre, heater fan won't cut off even when key is off.
Thanks Micheal, but what I need to know is which one of the 5 modules on my 1997 le sabre is the correct one, would also appreciatr it if someone could tell me the number of it. J.R.
Hi, I am new to this forum. I have a 1993 Buick Lesabre limited with the same problem. I found some info from this forum but so far I have not been able to resolve this problem. There is a 30 AMP fuse (green) in the MAXI control center that I have pulled to at least stop the blower from running. I have been under the right side dash and behind the glove compartment and unplugged items one by one but still not able to find one item that will stop the blower. I have pulled all the relays in the maci center as well. I have heard some info about a blower motor resistor but not able to find it yet. Does anyone have an idea as to where to find this resistor?
Warren501 |
I am having the same problem with my 93 buicke's blower motor. any descriptions or schematics of the blower motor control module or relays would be appreciated
re
Check out my post Heater A/C Malfunction to fix the problem
http://www.automotiveforums.com/vbul...Fc+malfunction It most likely is going to be the blower motor and the blower motor resistor. |
Re: re
warren501 |
Re: re
Warren501 |
