Old 09-19-2011, 07:28 PM
bsr2002 bsr2002 is offline
Question Antifreeze Leak
I pulled intomy driveway and noticed this leak. Water pump maybe?
http://www.youtube.com/watch?v=t8x7B8kIU3w
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 09-19-2011, 07:57 PM
gmtech79's Avatar
gmtech79 gmtech79 is offline
Could be. Run your hand under the water pump pulley. Or use mirror to to look under the water pump.
Sent from my Droid X. Typos probable.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 09-20-2011, 11:25 AM
Tech II Tech II is offline
Re: Antifreeze Leak
Don't think so.....that's wet on the opposite side of the engine where the water pump is.......look at lower intake gasket or follow the heater core hoses to the engine, there is an aluminum fitting the heater pipe goes into that could be leaking....
Check heater core hoses, radiator hoses, the thermostat housing, a radiator that may be spraying on that section.....
Old 09-20-2011, 02:48 PM
Re: Antifreeze Leak
This is directly under the pump. gmtech79, I ran my hand under the pump and felt no moisture...
Old 09-20-2011, 02:53 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: Antifreeze Leak
Looks like too much water drripping for it to be the water pump. It is probably just a bad hose.
The Following User Says Thank You to Tony Silva For This Useful Post:
bsr2002 (09-21-2011)
Old 09-20-2011, 03:32 PM
Re: Antifreeze Leak
I checked the 2 large hoses and no leaks. It seems to be coming thru this plate. It only has 2 bolts, guess I'll take it off and have a look...
Old 09-20-2011, 04:38 PM
Re: Antifreeze Leak
I left the car running and this is what I got... Any ideas would be greatly appreciated...
http://www.youtube.com/watch?v=_Pay0I0Igbg
Old 09-20-2011, 07:13 PM
Re: Antifreeze Leak
Someone on Facebook thinks it may be had gasket
Old 09-20-2011, 07:25 PM
gmtech79's Avatar
That's definitely the front side of the engine and not the rear as another commented said. In the vid I see coolant dripping from the front of the cradle. Have u loooked at the radiator? Especially the lower rad hose. Coolant can run down that hose and also drip through the engine mount of the cradle like your seeing. Look down from the top real good and also pull that rf wheel and look through the wheel well,may also have to remove the splash shield to see. Doubt it is a heat gskt.
Look real good around the timing cover also.
ASE Master
1984 Monte Carlo SS
1991 GMC C1500
The Following User Says Thank You to gmtech79 For This Useful Post:
Old 09-20-2011, 08:38 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Antifreeze Leak
Yeah that "plate" as you described it is the bottom of the motor mount cradle...you don't wanna take bolts outta that without supporting the motor, but that's irrelevant, has nothing to do with your leak.
You are leaking from the water pump, bypass hose or intake most likely, all would run down in that area. A pinhole in the bypass hose will often shoot a stream of water so small it's difficult to see, and usually downward, where it then runs down the front of the motor. When mine popped for a moment I actually thought I'd broken a head bolt, all I could see was coolant cooking off around the front lower head bolt...then I realized it was spraying there in a fine stream from the bypass hose...what a relief!
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
The Following User Says Thank You to jeffcoslacker For This Useful Post:
Old 09-21-2011, 12:57 AM
Re: Antifreeze Leak
Hey guys thanks! I'll be makin it an early morning and hope that's all it is! I'll take that wheel off and check it out!
I'll let yall know what I find!
Ben
Old 09-21-2011, 04:01 PM
Re: Antifreeze Leak
You were right Bro... I just didn't look hard enough at the smaller hoses! I feel soooo stooopid!
http://www.youtube.com/watch?v=F7bUYN17ksQ
Old 09-21-2011, 09:06 PM
Re: Antifreeze Leak
Bypass hose
BTW, if your upper radiator hose is the same age, it's about to blow too.
...empty gun rack.
Old 09-21-2011, 10:08 PM
gmtech79's Avatar
Originally Posted by jeffcoslacker View Post
Bypass hose
Likely any hose could blow if they are all that old.
ASE Master
1984 Monte Carlo SS
1991 GMC C1500
Old 09-22-2011, 11:01 AM
Re: Antifreeze Leak
Absolutely true, but bypass hoses and upper rad hose always seem to let go first...
...empty gun rack.
My 97 2door grand prix is has four leaks and etc HELP Universalsoul Grand Prix 4 08-23-2011 04:59 PM
Antifreeze odor & leak Silvio99 Tahoe 3 10-27-2010 11:19 AM
1994 Olds Achieva, 3.1 S Leaking coolant rastaron Achieva 1 09-23-2010 11:13 AM
90 REX B16 antifreeze leak Slacky '88 - '91 Civic | CRX | Wagon | Shuttlee 4 04-21-2004 11:08 AM
1997 grand am antifreeze leak coco345 Grand AM 1 03-07-2004 08:23 PM
