Old 09-07-2011, 05:30 PM
beest beest is offline
2002 accord rear caliper question
Good day all,
I have had a thumping brake pedal for a bit and knew that I had a warped rotor. I suspected the right rear by the wear pattern of the disk. I purchased the parts and started the job to see...what the heck is the cable and assembly on the outside of the caliper? After FINALLY getting the bolts off...not a great placement of this extra assembly...I pretty much had to beat the caliper off the rotor. I was afraid of this...I will have to replace the caliper as it appears to be seized.
Now...can anyone shed some light on what I would assume is the parking brake assembly? I have read some great info on the normal replacement of the pads/rotor...but what do I need to know about the cable and arms? Do I need to release the tension somehow? Does it need to be rigged? Is there a best way to do this?
Any and all help will be greatly appreciated.
Old 09-18-2011, 02:04 PM
BullShifter's Avatar
Re: 2002 accord rear caliper question
It's the parking brake cable. In order to get the piston in you will need to "screw" it in. It does not push in like a normal caliper.
2002 mountaineer rear power windows and wiper stops working juaniro Mountaineer 4 02-12-2010 07:22 AM
2002 Silverado rear caliper shield, transfer case fluid mrsparky637 Silverado 12 10-16-2007 06:42 PM
02 Accord Brake Caliper Question NesOne Accord/TSX/Accord Hybrid 3 02-19-2007 11:05 AM
1995 Accord rear speaker question... mrpatis Accord/TSX/Accord Hybrid 4 07-22-2004 10:33 PM
Tags
brakes , caliper
