Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 02-09-2010, 04:07 PM
juaniro juaniro is offline
Angry 2002 mountaineer rear power windows and wiper stops working
2002 mountaineer rear power windows and wiper stops working. i check the fuses and everything looks good. any ideas?
Old 02-09-2010, 09:49 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2002 mountaineer rear power windows and wiper stops working
Welcome to the forum!
Do the rear windows work from any of the switches (driver's door or rear doors)? How about if you open the driver's door with the key in the Run position? Did they stop working the same time as the rear wiper? Others have experienced issues with the wires to the rear glass breaking in the rubber wire conduit to the rear. The same issue is pretty common to the driver's door and may be the cause of the rear power windows not working.
Or by rear power window are you referring to the very rear window power release?
-Rod
Old 02-10-2010, 07:46 AM
the rear windows are not working with any switches. and the wiper quit working at the same time as the rear windows. is there any relays or any other idea? i check the wires and everything looks ok!
Old 02-11-2010, 09:14 PM
shorod's Avatar
SHO No Mo
How comfortable are you with a test light and/or DMM?
-Rod
Old 02-12-2010, 07:22 AM
i'm ok with the test light! what can i do?
thx
Tags
2002 , mountaineer , power , windows , wiper
