Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-05-2011, 08:52 PM
tannerr52's Avatar
tannerr52 tannerr52 is offline
Wheel Squeak
I have no idea of what this problem is... My car has a little over 200k on it. It does have new brakes on the front. I can hear the wheels squeak when I drive. It only does it sometimes, but i can hear it the most going around 30 MPH but it will speed up as I speed up, etc. Like I said it only doesit sometimes. I have no idea of what it is. I bought it after brakes were put on, btw.
Thanks.
Tanner
1990 Pontiac Bonneville- 200k -3.8L SOLD Bye Bonnie I'll miss you.
1998 Jeep Grand Cherokee Laredo- 5.2L V8 - 140k TOTALED You were an ok Jeep...
Current ride:
1996 Jeep Grand Cherokee Laredo- 4.0L L6 - 110k
Old 09-06-2011, 12:32 AM
Johnnyx1257 Johnnyx1257 is offline
Re: Wheel Squeak
I don't think it's bakes. But I'm not to sure what it really could be
http://twitter.com/johnnyx1257
Old 09-06-2011, 01:17 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Wheel Squeak
Thanks.
Tanner
Could still be the new pads rubbing against the disc?
Do you know if the calipers were done, or bleed properly afterwards?
Could also be wheel bearing going bad, but they normally make rumbling, or growling noise rather than a squeak.
Old 09-06-2011, 02:56 PM
Re: Wheel Squeak
Just curious if you figured itout yet?
Old 09-06-2011, 09:21 PM
tannerr52's Avatar
Re: Wheel Squeak
Havent figured anything out yet. I have NO idea. i drove it a little today and made a few observations. I can hear the noise,as always. when i turn slightly, the noise gets quieter and the noise is more solid. (more of a long squeak than a lot of short squeaks) also! when i brake, the noise quiets but doesnt go away. Im guessing only the pads were replaced?
Current ride:
Old 09-06-2011, 09:51 PM
Re: Wheel Squeak
I'm stumped sorry. Maybe the caliper
Old 09-06-2011, 09:56 PM
tannerr52's Avatar
Re: Wheel Squeak
Anybody else have any ideas?
Current ride:
Old 09-07-2011, 06:46 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Wheel Squeak
Have you taken the wheels off and carefully inspected the brakes, looking for signs of anything rubbing on the rotors? Could you find a road with buildings or a concrete wall on one side that you could drive down with windows open to at least determine if it's coming from one side versus the other?
I'd start by inspecting the brakes, paying particular attention to the dust shields to see if a dust shield is bent and touching the inside rotor surface. Since the noise does change when you apply the brakes, it could be an issue with the brake pads that were installed. I've had this issue before when using the inexpensive brake pads. Sometimes getting up to speed when there are no cars around and then slamming on the brakes would quiet the noise for several miles. If the same works for you, you probably will need to replace the pads with some higher quality pads to get the noise to go away.
-Rod
Old 09-07-2011, 08:55 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Wheel Squeak
Sounds like the calipers are not sliding on their guide pins smoothly like they should. If they stick, one of the brake pads will always be in contact with the rotor.
Also, an anti-squeal compound can be applied to the back side of the pads to help keep them from moving in the caliper and absorb any vibrations. I like CRC Disc Brake Quiet. Apply, let it get tacky, and install. Coat the entire back side, past any glued on shims. It also helps prevent rust that can cause the pads to become misaligned in the calipers.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-07-2011, 10:54 PM
tannerr52's Avatar
Re: Wheel Squeak
I have a feeling that the cheap brake pads might be the case, although i havent tried that trick yet. Ill look into that tomorrow.
Thanks
Current ride:
Old 09-07-2011, 11:43 PM
Re: Wheel Squeak
It could be the Cheap pads I used auto zones duralast once and they squeaked for like 3 days while driving then it just stopped lol
Old 09-11-2011, 03:01 PM
michaelpotte michaelpotte is offline
Re: Wheel Squeak
Get some copper grease on the back of those pads. Should help.
Old 09-12-2011, 11:18 AM
jdmccright's Avatar
The RustBuster
Re: Wheel Squeak
I like the Duralast Gold pads. The backing shims are uncoated stainless steel and hold up well against rust development and debonding from the steel pad base.
I recall a Duralast line that had precoated backing shims, but I have found that any soft material between the shim and caliper just contributes to causing misalignment of the pad once it deforms under the pressure. The CRC compound applied to a bare shim does a good job of quieting the squeals but stays soft enough that it is all squeezed out where the caliper contacts the shim then sets up to hold the alignment.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 09-21-2011, 10:48 PM
tannerr52's Avatar
Re: Wheel Squeak
OK. Sorry guys, but ive been busy. I havent done anything yet. But! when i back up my diver side front squeaks really REALLY bad. It only happens when i get up to about 5 mph, and its a terrible squeak.
Current ride:
steering wheel squeaks..? sharpx Impala | Impala SS 10 02-02-2006 11:16 PM
Wheels Squeaking shyguy5885 Grand AM 6 08-26-2005 12:03 PM
97 Caravan Wheel Squeak diyguy Caravan | Voyager 2 03-14-2005 12:03 PM
wheel squeaks after warm up golden_briar02 SC/SL/SW 2 01-23-2005 03:20 PM
Front Wheel Squeak 2000gtp Grand Prix 3 09-21-2004 07:35 AM
Tags
bearings , bonneville , brakes , squeak , wheel
