Old 09-01-2011, 10:26 AM
greer13 greer13 is offline
1998 Jimmy Front Vibration
I have this vibration on the front drivers side when truck gets above 25 mph. If I turn wheel to left it subsides a bit. I have replaced u-joints in both drive shafts and also the ball joints on the drivers side. Wheel hub is my next item to replace, however yesterday I jacked the truck up and took off brake caliper and rotor to inspect bearing and when I spin the hub the front drive also spins and if I spin the passenger side wheel the drive shaft does not spin. Is that how it suppose to behave? I am not sure the wheel hub in the problem anymore. Any ideas?
Old 09-04-2011, 07:27 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1998 Jimmy Front Vibration
Yes that the way it works in 2W.
I would check the tire balance/slipped belt/bemt wheel.
Try swaping tires and wheels.
Jack it up with all 4 wheels off ground in 4W and speed it up to 25 PH or more and watch for tire hop or wobble or sliped bet on tire.
Let us know how it goes.
MT
Old 09-04-2011, 07:39 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Thats a good thing, it's how an open differential works
Simple question, have you had the wheel and tyre balanced recently?
It may have just thrown a weight.
Car Trouble - GMC Jimmy '98 Snowbder09 Problem Diagnosis 4 07-21-2011 01:38 PM
Vibration at high speeds uspres2020 Grand AM 4 07-19-2009 07:23 PM
1998 jimmy front signal lights and rears won't run off. Not flashing CanukGMC Problem Diagnosis 11 05-27-2009 11:41 PM
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 09:16 PM
1998 JIMMY front end pop.....>>>>>> bigbadbowtie Jimmy 19 02-06-2005 07:12 PM
