Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-24-2011, 04:17 PM
89crown 89crown is offline
changing fluids in the transfer case
Can I also change my fuilds in my transfer case as well on this same truck 2003 gmc 5.3 4x4 z71 with a automatic transfer case. Can I also do this at home to in order to save myself some cash rather than take it to a dealership and in up spending a forture. Thanks
Old 08-24-2011, 04:51 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: changing fluids in the transfer case
Of course you can do it at home!
You need to locate the drain plugs and fill points and work out the correct level.
Make sure you do it on a flat surface, and be aware that filling it could be difficult if it uses a side mounted fill plug.
What fluid goes in the transfer case?? Feel stupid for asking, lol!! team_losi123 Rodeo | Passport | MU 2 06-21-2010 01:44 PM
Tranny Fluid in transfer case vacuum switch lines ???? scholzee Problem Diagnosis 6 01-02-2008 03:34 PM
Transmission Fluid in Transfer Case sediver Jimmy 7 04-21-2006 10:07 AM
any change fluid in transfer case steve420 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 09-11-2005 08:21 AM
fluids for the transfer case brokesilverado C/K 7 01-28-2005 04:20 PM
