Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 09-10-2005, 11:25 AM
steve420 steve420 is offline
any change fluid in transfer case
has i listed in another thread my nissan dealership is not to confident in the answers to my questions. the transfer case for and automatic transmition takes atf III right. about how many quarts would it take. is there any problems i might run in to .
Old 09-10-2005, 12:26 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: any change fluid in transfer case
I use GL4 oil.
http://www.automotiveforums.com/vbul...ad.php?t=76717
Xterra4x4.com and the Xterra Offroad Webring
Old 09-10-2005, 06:16 PM
so the transfer case in an automatic xterra is gear oil no ATF III. why would it matter what transmition you have. dose the fluid from the automatic transmition flow through the transfer case
Old 09-10-2005, 11:50 PM
XTerra Guy
The transfer case gear oil does not flow with the automatic transmission oil. They are separate units. Some people with Automatics use ATF, but I have stayed with GL4 in my standard as it doesn't corrode the brass fittings like GL5. Nissan didn't do anyone any favors by using a gear oil that is pretty hard to find. There are some synthetics like Royal Purple that are easier to get at Xterraparts.com or other stores. Our club bought a drum of the correct GL4 for members to use.
Here's another good thread.
http://www.automotivehelper.com/topic63102.htm
Old 09-11-2005, 08:21 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
I have Mobil 1 ATF in both the auto trans and the transfer case.
When did you last check your spare tire's pressure?
