Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 08-22-2011, 07:03 PM
fatmac fatmac is offline
92 TS 3.8L cooling fans
I am working on my daughters TS, it has been overheating. Water pump is fine and the thermostat is working fine also. I did notice that the temp gauge on the dash isn't. I have noticed that the fan isn't coming on either. I don't have a book on this car or a owners manual. So I am unsure of which fuses to check. I did try turning on the AC to MAX to see if that would start a fan, and that didn't work either. So guys I need some input on where to look for the relays and fuses. Thanks to all!!
Jack
Old 08-24-2011, 02:47 PM
Tech II Tech II is offline
Re: 92 TS 3.8L cooling fans
What do you mean the temp gage doesn't work?
How is the coolant level in the reservoir AND the radiator?
Any codes?
Old 08-24-2011, 04:41 PM
The coolant level is good. I have let it run up to temp and the thermostat does open. The temp gauge on the dash is the one I was referring to. I don't have a OBD or any other type of code reader to pull codes.
Jack
Old 08-24-2011, 04:44 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Usually he gauge and fans are run off different sensors, but if the gauge isn't working, how do you know it's over heating?
Have you checked there is good flow through the system, the radiator isn't blocked, or a hose kinked?
Old 08-24-2011, 04:51 PM
Well from what she had told me. It will cut off and the engine will be smoking.
I have noticed this also testing it the other day. It does seem to have good flow once the thermostat opens, I can rev it up the level in the radiator goes down and when I let off of it, it comes back up. I have tried to get the fans to come on by turning on the AC on max, for me that didn't work.
Old 08-24-2011, 04:59 PM
Moppie's Avatar
Master Connector
But I take it you havn't been able to replicate the problem yourself?
If it's been overheated to the point that is siezes up, then you may have bigger problems than the fans not running
Old 08-24-2011, 05:14 PM
That does seem right Moppie, I didn't want to push it that far it already has a knock at the point it is accelerated but goes away after it comes up to speed.
Just about to the point to tell her while it still running to go trade it in. But her money is tight. Just trying to keep it on the road. I think if I could just get the fans to run that would do it.
Old 08-24-2011, 05:18 PM
Just a side note. The other cars I keep running are...
95 Lincoln MK VIII,
92 Volvo 940 wagon
94 Ford Ranger
02 Dodge Durango.
The Lincoln is my baby with 240,500 miles and have driven it till the wheels have fallen off, fix it and still driving it.
Old 08-24-2011, 05:19 PM
Moppie's Avatar
Master Connector
How long have you let it idle for?
Just idling it will often take 10-15min for the engine to heat up enough for the fans to come on.
You can test the fans by unplugging them and connecting them directly to the battery, that is a quick way of ruling them out as being a problem.
Next step is to find the fuse, or relay they are off (should be labeled) and check those.
Then find and check the temp sensor.
Old 08-24-2011, 05:42 PM
Yep that was as long as I let it run. I will try the hot wire trick. I don't have the owners manual or a Chilton type of book so I am not sure of which fuse I need to look at. I do think I found the relays, they are the ones behind the passinger headlight. But there are four so which one is which??
Old 08-24-2011, 05:45 PM
Moppie's Avatar
Master Connector
They are normally labeled, usually on, or under the cover for the relay/fuse box.
Old 08-24-2011, 05:52 PM
Covers would be nice.
Old 08-24-2011, 06:12 PM
Moppie's Avatar
Master Connector
Doh.
There must be a diagram of the layout somewhere online..
Old 08-25-2011, 09:17 AM
LMP's Avatar
LMP LMP is offline
www.avigex.ca/xport/relays.jpg
www.avigex.ca/xport/fandiagram.jpg
www.avigex.ca/xport/instrumentpanel1.jpg
www.avigex.ca/xport/enginesensors1.jpg
temp sensor for the ECM control (2 wires) is not that for the i/p (single wire).
Is your a/c actually working? if a/c refrigerant is depleted and pressure is low, it will not turn the a/c clutch ON nor the fans. But engine temp control would still be working and should activate them when needed.
www.avigex.ca/xport/accompressorcontrol.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Cooling Fan sensor.....please read! Baffled! diecast92 Engine and Transmission 10 07-31-2011 11:23 AM
'85 Calais cooling fan relay location saxonmor Cutlass Series 0 07-07-2010 09:03 PM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 08:08 PM
98 3.8l cooling fan fuse blowing CnlK Bonneville 3 05-13-2009 04:24 PM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
