Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 07-29-2011, 12:32 PM
diecast92 diecast92 is offline
Angry Cooling Fan sensor.....please read! Baffled!
I have searched the forums and can't find anything specifically related to this topic. I have a 1992 Camaro RS with a 5.0 V8 and automatic transmission. The cooling fan stopped kicking on when the engine would get hot, but works fine if you turn the air conditioner on. After searching the forums, I changed the cooling fan sensor located on the passenger side of the engine block. Started the car and let it get up to temp and the cooling fan kicked on all by itself when the engine got hot! I drove the car for most of the evening without an issue. I assumed that was the problem. I got in the car the next day and the same thing is happening.....cooling fan will not kick on by itself but will turn on with the air conditioner. I double checked the cooling fan sensor connector and wiring and it's fine. I ran a ground wire to the fan sensor connector and the fan turns on. Any other thoughts on what could be wrong? Is there a way to test the cooling fan sensor to ensure I didn't get a bad one from the parts store?
PLEASE HELP!
Old 07-29-2011, 01:04 PM
inafogg inafogg is offline
Re: Cooling Fan sensor.....please read! Baffled!
are you sure you replaced the right sensor??
the engine coolant temp. sensor (ect)is located by the thermostat housing.
you dont want to use any teflon tape on the threads.
it does sound like a bad sensor.some after market sensors take longer(higher temp)before it turns on the fan,how hot does the guage read when its overheating
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
diecast92 (07-30-2011)
Old 07-29-2011, 03:26 PM
I may have called it the wrong sensor, but I replaced the sensor that turns the fan on and is located on the passenger side of the block between the #6 and #8 cylinders. I did not use any teflon tape on the install. The temp guage got as high as 260 before I turned the air conditioning on to activate the cooling fan. After that, it cools right down to 220 and stays there. Although the factory guage read 260, the radiator was not boiling over into the overflow tank. Any thoughts?
Old 07-29-2011, 04:30 PM
is this the 1 you replaced?
http://www.autozone.com/autozone/rep...erature+Sensor
Live For Today
Yesterday is gone,
Old 07-29-2011, 08:29 PM
No, that is not the one I replaced. This is the one I replaced:
http://www.autozone.com/autozone/par...mString=search
Old 07-29-2011, 10:35 PM
you need to replace the ECT sensor thats the 1 that turns fan on/off by temp.
i think disconnecting the sensor automaticly turns fan on
but you can check voltage at fan when hot to verify sensors bad
but not much fun hot!!!
Live For Today
Yesterday is gone,
Old 07-30-2011, 07:11 AM
Which sensor is the ECT sensor? Is it the one next to the thermostat?
Old 07-30-2011, 11:01 AM
yes
Live For Today
Yesterday is gone,
Old 07-30-2011, 05:41 PM
yes
OK! I will try and buy one tonight and get it put in. I'll let you know! Thanks for the information! I do appreciate it.
Old 07-30-2011, 08:32 PM
That was it! Thank you INAFOG! I appreciate you helping me out !
Old 07-31-2011, 11:23 AM
glad to help
Live For Today
Yesterday is gone,
'85 Calais cooling fan relay location saxonmor Cutlass Series 0 07-07-2010 09:03 PM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 08:08 PM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
96 GP se - a/c, cooling fan, sensor connection question mmcin50 Grand Prix 4 06-20-2007 12:56 PM
if cooling fans have quit, read this. micali Impala | Impala SS 3 01-28-2006 04:37 PM
Tags
cooling , fan , sensor
