Old 06-30-2009, 05:45 PM
drtyrocker drtyrocker is offline
Angry cavalier 99 cooling fan
Got cooling fan circuit error. fan runs with fused jumper and doesn't blow fuse. Run car to temp and relay kicks on but fuse blows either immediately or a few seconds later. I even jumped the circuit from positive fuse terminal to relay output and the fuse didnt blow. Voltage is around 12.75. Resistance on the circuit is around .5 Ohms. Any ideas would be great.
Old 06-30-2009, 09:48 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: cavalier 99 cooling fan
So essentially you bypassed the relay? Remove the relay and jump 30/86, I'd bet there's a short in the relay.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-01-2009, 12:53 AM
Yes I bypassed the relay. Ok I'll check that out.
Old 07-01-2009, 08:08 PM
J-Ri's Avatar
I made a typo, I meant 30/87... hope you caught that
Tags
1999 , cavalier , cooling , fan , p0840
