Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-08-2009, 11:11 AM
CnlK CnlK is offline
98 3.8l cooling fan fuse blowing
Was asked by a friend to take a look at their car, overheated in a drive-thru, suspected cooling fan problem. Found blown 40amp maxi fuse in the underhood fuse panel. Installed another fuse, fans fired up and then turned off which I suspect was normal, then had her turn AC on, fans weren't operable then. Checked fuse and it was blown again. I don't know if fuse blew after initial start up or after AC was engaged. Any common faults to look at? It looks like there is a large resistor wired just prior to the drivers side fan. And car was involved in a front end collision this winter, bumper is shifted, wasn't aware of any other radiator or front end damage. Any suggestions appreciated.
2014 Chevy Equinox 2.4L, 2010 Grand Caravan 3.8L
Old 05-08-2009, 12:41 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 98 3.8l cooling fan fuse blowing
I'd unplug the fans, then see if the fuse blows when they are commanded on, this would narrow down whether or not the actual fan motor(s) are the problem- if fuse does not blow- then I'd wire a 30 amp inline fuse to power the fans separately- decide which fan is bad if the inline one blows- and replace the bad motor-- or if the 40 amp original fuse blows without the fans plugged in-- I would look for the short circuit- (frayed, cut wires etc) between the fans and the fuse center...
Good luck
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-08-2009, 02:02 PM
Thanks for the tip. There is a plug between the two fans, I'll unplug that one which would disable the pass. side fan and see if fuse blows. It appearred as if the drivers side fan was wired directly to that resistor block. Wondering if it could get by with one fan? Hot summer temps would probably be a problem. Has anyone had that resistor fail? Would assume that would cause a higher amperage draw if resistance was less than specified. Hoping its not a bad wire as car was in a collision this winter.
Old 05-13-2009, 04:24 PM
Had a few minutes today. Unplugged the three wire connector at the driver's side fan & installed new fuse. Pass. side fan is operable and fuse doesn't blow. At this point one fan is better than none. She is looking to unload car as transmission is slipping.
