Old 08-21-2011, 06:41 PM
mmguy's Avatar
mmguy mmguy is offline
Floor shifter 1997 Jimmy
Need some ideas.
Have a 1997 Gmc Jimmy and automatic transmisssion,Has a floor shifter and is stuck in park. Seems to un stick if you bounce it around.Had it tow after trying to get it out of park. Got it home now it is working. Just had a transmission put in 3 months ago. What could be wrong( cable, a switch )
Thanks
Old 08-22-2011, 04:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Floor shifter 1997 Jimmy
Originally Posted by mmguy View Post
Need some ideas.
Thanks
Floor shifter gets a lot of stickey stuff spilt in them and other stuff.
Pull floor shifter cover and check shifter release solenoid or wiring or shifter release.
If any stickey stuff or trash in there clean it up.
Is this one you have to step on brake to release shifter?
MT
Old 08-22-2011, 05:30 AM
mmguy's Avatar
Yes you have to press the brake to release.Wife told me did it once before and they jack up truck and it release it.
Old 08-22-2011, 06:06 AM
MT-2500's Avatar
AF - Advisor
Then the brake switch trips the solenoid on shifter or shift cabel.
Make sure fuse is good and brake switch is switching solenoid.
MT
Old 08-24-2011, 12:39 PM
mmguy's Avatar
Found the probelm. Shift cable was starting to rust apart.Replace shift cable just have to adjust it now
thanks
The Following User Says Thank You to mmguy For This Useful Post:
blazee (08-31-2011)
Old 08-24-2011, 02:53 PM
MT-2500's Avatar
AF - Advisor
thanks
You are welcome and thanks for posting back how it went.
Good liuck.
MT
'95 Riviera: Floor Shifter Button Hard to Engage Colt Hero Riviera 4 03-08-2007 08:24 AM
Want to Convert; Auto Steering Column Shifter to B&M Auto Floor Shifter thedeem0n Chevelle 1 06-04-2006 11:22 AM
1977 Dodge B100 Van Floor Shifter Jackie321 Ram Van 1 10-18-2005 08:21 AM
wobbly tilt steering column with floor shifter guahanx Sierra 3 10-20-2004 07:39 AM
column to floor shifter swap....powerglide CHINGAS Camaro Discussions 0 02-13-2004 10:50 PM
