Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 08-11-2011, 01:20 PM
usual suspect usual suspect is offline
99 sable cruise light flashes
A friend has a 99 sable ls. After the cruise is turned on, when the set/accel, resume or coast buttons are pushed the green cruise light just flashes and the cruise never engages. Happens at all speeds. Ideas?
Old 08-11-2011, 02:39 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Re: 99 sable cruise light flashes
Could be caused by a couple things.
- Vehicle speed sensor
- Brake lamp switch
Does the vehicle have a check engine light?
Have you tried looking at the ECU for a trouble code?
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 08-11-2011, 04:41 PM
We replaced the brake lamp switch if it's the one attached to the brake pedal. No check engine light. Don't know what the vehicle speed sensor is. I believe each wheel has a speed sensor for the ABS. Is this something separate? Haven't checked ECU codes. Do we have to take it to a mechanic for that? Thanks.
1999 Sable Airbag light on steady - no flashing mechman58 Sable 1 09-06-2008 03:53 PM
96 Sable, Speedo drops to 0, OD Off light flashes sandiegodude Sable 1 08-19-2008 06:48 PM
Cruise not working and O/D off light flashes jmurph4 Windstar 3 10-31-2007 12:26 PM
91 Sable Airbag light flashing Wren84F Sable 1 06-10-2004 09:15 AM
92 sable LE air bag light flashes 3+2 fwest32 Sable 6 09-01-2002 09:53 PM
