Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 06-03-2002, 05:04 PM
fwest32 fwest32 is offline
92 sable LE air bag light flashes 3+2
greetings:
my 92 sable LE air bag dashboard light flashes 3 times then pauses then flashes 2 times then pauses again repeating this cycles continuously.
what does this mean? is it a code? dealer says to bring the car in but gives no info.
any help appreciated.
Old 08-17-2002, 11:11 PM
fordman123 fordman123 is offline
Air bag light LFC code 32
AHHHHH the famous LFC code 32
LFC= Lamp Flash-out Code.
Gimme some details.
Does the horn sound?
Cruise work?
Hmmm..
May be the clockspring ??
Good luck!!
Fordman123
Old 08-20-2002, 09:53 AM
hey FORDMAN123:
add'l info:
0.1 megamiles
horn works ok
don't use cruise - mosly city driving
on other problems are antenna stuck up and squealing belts even with
treatment
mainspring ok too
thanks
fwest32
Old 08-20-2002, 08:32 PM
Here is what is going on with your car.
Your airbag diagnostic monitor is seeing the resistance out of tolerance for the circuit(s). So either there is a bad connection causing this high resistance, or could be a broken wire causing the resistance to be infinite (otherwise 0.L outta limit)
Could also be poor contact inside the clockspring or the diagnostic monitor.
Double check ALL of your fuses.. sounds dumb but sometimes it
winds up being a fuse!!!
If all fuses are good,
One of 3 things:
Air bag diagnostic monitor
Clockspring
Wiring problem either circuit 614 (Gray wire w/ Orange stripe)
OR cirucit 615 (Gray wire w/ White stripe)
If you don't have the proper tools to test this with, I would
not recommend that you attempt this repair.
Could cost big dollars!!!
I wish I could be of more help!!
fordman123
Old 08-21-2002, 12:27 PM
good go fordman:
will avoid collisions for now and check the fuses and connectors. my farmboy solution is a big square piece of electrician's tape over the flashing light to avoid becoming hypnotized. were you pulling my leg about the clock spring? i think the clock is electric.
bye bye
Old 08-30-2002, 09:50 PM
No leg pulling here!! LOL
That's what most people call it.
Ford parts systems call it "air bag sliding contact"
Later
fordman123
Old 09-01-2002, 09:53 PM
decode the trouble codes?
hey hey fordman,
i'm gonna try fixing it myself. where can i find circuits 614 & 615? do they show the clockspring? i have a haynes repair manual, milliohm meter, etc but am reluctant to attempt repair without a step by step manual to guide me. does ford sell such a thing or can i find it on line?
my dodge caravan (89 2.5L turbo) manual has the entire trouble code and shows how to reset the computer after repairs. what is the full trouble code list for my 92 sable?
thanks mucho
fwest32
