Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 08-01-2011, 07:57 PM
sverker sverker is offline
Hard shifting
A friend came by with his Trans Sport (european name for the Venture) 2000 which when getting warm starts to shift hard. I connected my ODB-II adapter and we went off for a drive. After a while, maybe 20 minutes, the hard shifting started. I could not hear any difference in sound, i.e. no whining nor was there any trouble code set by the PCM.
I am suspecting it's the common problem with PCM solenoid, as described by TSB 00-07-30-002B, but shouldn't it set a code when that happens?
I had not yet discovered that I could add "GM specific pids" to my application (torque on android phone) but that shouldn't affect the ability to collect trouble codes being set by PCM, or?
Old 08-02-2011, 09:36 PM
lesterl's Avatar
lesterl lesterl is offline
Re: Hard shifting
Also Pontiac version of the Venture.....
I have never had great luck capturing Trans codes, suspect it is because mine is a 97? I would suspect the PCS (the modulation valve that is common to give fits.)
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 08-03-2011, 05:21 PM
Re: Hard shifting
Yes, I also suspect the PCS. He had talked to some workshops earlier that told him they had to do a rebuild for about $5k... He's going to call the dealer workshop with reference to the TSB mentioned above to see if it's something they are familiar of.
Old 08-03-2011, 06:11 PM
kornjulio kornjulio is offline
Re: Hard shifting
My van exhibited very similar symptoms. Had a local shop change all the solenoids in the valve body; including the PCS solenoid. Shifts much better now. Cost was around $600.
2000 Venture - repairs to date:
LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!)
Old 08-10-2011, 03:26 AM
Christophe Salvain Christophe Salvain is offline
Re: Hard shifting
Maybe a stucked or seized PCS.
Presssure doenst go down when transmission shift.
There's 4 Pressure Control Solenoid : 1-2, 2-3, 3-4 and a master one on 4t65 – e, enhanced transmission, auto 4 spd, hmd (3,4 litres).
I fixed twice the problem on two '00 and '03 Venture and a '91 TransSport by following instruction :
- drain the trans,
- change oil, filter and gasket,
- add Lubegard Automatic Transmission Fluid (ATF) Protectant http://www.lubegard.com/C-112/LUBEGA...uid+Protectant
Purchase Online : http://www.midwayautosupply.com/p-12...-oz-50902.aspx
It frees stuck valves in valve bodies.
BTW, I resell the PCS that I bought for nothing
Rgds.
Old 08-11-2011, 02:08 AM
Re: Hard shifting
Interesting. Did you do a full flush of the system or just dropping the pan and changing the oil you got out there?
Old 08-11-2011, 03:01 AM
Re: Hard shifting
My mechanic just dropped the pan and changed the oil in it only.
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Please Help 95 Blazer shifting hard ryanusrey2012 Blazer 4 05-26-2011 09:53 AM
Gear selector hard to shift serge_saati Windstar 16 06-05-2009 09:57 PM
S-10 hard 1 - 2 hard shift joslinm Problem Diagnosis 5 03-09-2009 05:33 PM
95 sl hard shift and hard start wkmaylish SC/SL/SW 9 06-10-2005 12:53 AM
