Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-30-2011, 09:37 PM
mike_dmt mike_dmt is offline
84 Caprice needs heater core?
Have a coolant leak under the A/C box under the hood. Not from the hoses. Should I assume it's just a bad core? Do I change it from the engine compartment, or behind the glove box?
Old 07-30-2011, 09:48 PM
danielsatur danielsatur is offline
Re: 84 Caprice needs heater core?
I would consider bypassing the Heat core for a temp fix.
1) Disconnect the heater core from the outsider of the fire wall connection.
2) Connect the two hoses together with hose clamps and piping.
If the fluid is sweet smelling it's going tobe a bad heater core, if it's water it look for a block AC drain.
Old 07-30-2011, 09:54 PM
Yeah, I have it bypassed now, and it was coolant for sure. I was just wondering how to access it for replacement mostly.
Old 07-30-2011, 11:07 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You're in luck, the heater core can be removed from under the hood, and you don't have to spend a whole lot of time (work) doing it, either. It's not a tough job. GM used the same design on this from 1977 through 1990 so parts should be available. When I replaced the core on mine about 4 years ago, the new part cost $29 at Autozone.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-31-2011, 08:51 AM
j cAT j cAT is offline
the replacement would be removal of the top cover from the engine compartment. using air pressure check that it is leaking at the core. 15 psi / with some soapy water...
when installing or closing up this air box use sealers to prevent underhood air from being injested into the ac/ heating air box..
Heater Core Help emmaandleesmom SC/SL/SW 3 04-01-2010 11:43 AM
2002 Saturn L 300 heater core replacement Dadsvan LS/LW 0 03-22-2010 11:17 AM
97 k1500 z71 silverado, BLOW THE HEATER CORE???? kokopelli85 Silverado 6 01-12-2010 07:38 PM
1998 ACHIEVA Heater Core darkflame64 Achieva 1 12-31-2009 03:05 PM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
