Old 07-22-2011, 03:50 PM
JLKINSER1970 JLKINSER1970 is offline
ABS light on but no code (97 Bravada)
My ABS light has been going on and off for about a week now. It comes on while I am driving and stays on but if I turn the car off and back on, it goes off but comes on again while I am driving. The ABS system has even activated a few times when I was stopping on dry pavement. I took it to a shop down the street and he put his ABS scanner on it and no codes were found. So he used another scanner and no codes showed up even though the light was on.
I replaced both front wheel bearings about 2 months ago and they came with new speed sensors.
Any ideas??
Today the ABS system kicked in wen I applied the brake and the ABS light never came on.
Old 07-22-2011, 07:21 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: ABS light on but no code (97 Bravada)
Check your connections at the wheels for the ABS. A poor or bad connection will usually cause this. Unplug the connector bend the metal tabs inside a little and reconnect it, for a better connection.
Old 07-22-2011, 07:35 PM
danielsatur danielsatur is offline
Use CRC electric cleaner + dielectric grease on connectors.
Old 07-22-2011, 09:10 PM
old_master's Avatar
Advisor/Moderator
The ABS does a self test each time the vehicle is started, when the vehicle is moved at approx 5 mph, the wheel speed sensors are checked and the module completes the self test. If the orange ABS light comes on, a code is set in memory. The code will remain in memory until the ignition is shut off, then it is cleared. This is probably why your tech can't find any codes in memory.
Very common problem. This should help with diagnosis & repair:
http://ww2.justanswer.com/uploads/he..._coming_on.pdf
You have to know how it works,
to figure out why it doesn't.
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
ABS light reset code thisisme Ram Pickup | Ram SRT10 1 04-16-2006 11:28 PM
ABS light, no codes found dpollard Jimmy 3 01-05-2006 12:36 AM
no ABS light but constantly on natalie1031 Grand AM 3 09-15-2005 08:46 PM
ABS light on Codes indicate a faulty valve, Pump or Control Unit????? Evan Evans - LNS General Discussion 6 12-11-2002 09:04 PM
