Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-21-2005, 07:30 PM
dpollard dpollard is offline
ABS light, no codes found
This forum has been very helpful in the past, I hope it will be again.
My ABS light has been on for a while now, but its time to get through inspection and doubt it will pass that way. (wake county, NC)
I had a local shop check the code a while back (I can't find where I wrote it down $%^&*), but remember them saying it was most likely the high dollar controller.
I now have a obd2 scanner (Actron CP9145) but am not getting any codes relating to the brake light (just a pesky P0420 cat efficiency problem)). Is there something special about getting the brake codes?
After checking My haynes I am really confused - the book lists a bunch of c02xx codes that I am not getting on the scanner. My scanner manual groups this code range in "air metering". The haynes book also mentions that not all scanners access these codes - maybe mine doesn't (bummer). However, several postings I've searched here don't seem to even match to that number format - like 1821?? What am I missing here?
If I can't fix it cost effectively, does anyone know how to shut it off for inspection? Maybe pull a wire off the dash indicator or something?
You might need to know its a 95 jimmy 4.3 (w) 2 door 4x4
Thanks in advance
Dave
Old 10-22-2005, 08:23 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: ABS light, no codes found
Thanks in advance
Dave
Your code scanner will only retrieve powertrain codes.
You will need a more advanced scan tool (Tech1 or 2 or a Snap on scanner to retrieve ABS codes)
Your vehicle should pass, the base brakes still function correctly.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-22-2005, 08:58 AM
Thanks for the info GMMerlin. I hope you're right.
Wouldn't you know it, I found the code ten minutes after I wrote my post.
The code was ATWC1265 Open motor relay circuit. It seems to me this could be a simple wiring issue. Anyone know where I can fnd a diagram or layout of this circuit to check out? And will the light reset automatically if the problem is fixed or does it require a manual reset?
Thanks,
Dave
Old 01-05-2006, 01:36 AM
tech1029 tech1029 is offline
Thanks,
Dave
I know it is kind of late but it may help others. I just had my 99 jimmy repaired for that exact problem. My wire broke on my right front hub right where it clamps to the frame. I hear the wire is replaceable on some hubs. I replaced the whole hub though. When my mechanic scaned for codes it told him open circuit right front hub.
