Old 07-19-2011, 01:29 PM
bjd088 bjd088 is offline
Hard Shifting
Hi I have a 1990 PA with 153000 miles on it. A while back I had the Mass Air Flow sensor go out in it, causing all kinds of RPM issues. Afterward, the shifting was hard and jerky. Also, when I'm taking a left turn, the transmission doesn't seem to engage at all. I'm hoping it's a CV joint or something cheaper than the Tranny. Any help is appreciated.
Old 07-20-2011, 11:34 AM
trannyman52 trannyman52 is offline
Re: Hard Shifting
Early 4T60s trans had a vacume modulator,,,this controls trans line pressure,,,if you were fooling with MAF,,,,you my have bumped,,,disconnected a vacume line,,,which will allow modulator to sence a wide open throttle,,,lotsa line pressure,,,bumpy shifts.......
This trans also has issues with the oil level,,,especially on turns,,,curves on road,,,,over-fill trans by about a quart,,,will not hurt trans,,,won't blow seals or other BS......
The Following User Says Thank You to trannyman52 For This Useful Post:
bjd088 (08-08-2011)
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 05:42 PM
Please Help 95 Blazer shifting hard ryanusrey2012 Blazer 4 05-26-2011 10:53 AM
Gear selector hard to shift serge_saati Windstar 16 06-05-2009 10:57 PM
S-10 hard 1 - 2 hard shift joslinm Problem Diagnosis 5 03-09-2009 06:33 PM
95 sl hard shift and hard start wkmaylish SC/SL/SW 9 06-10-2005 01:53 AM
