Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-09-2011, 08:48 PM
sharkmonkey sharkmonkey is offline
2001 1500 dies after warmed up
I just picked up a 2001 1500 2WD 5.2L 5 speed today. It started up and ran great. I drove it around town then took it out on the freeway. After it was fully warmed up, I exited the freeway and stopped at a stop sign. The engine died and when I start it back it, it dies again unless I hold the throttle pedal down (keep the revs about 1k).
I pulled out a spark plug on either side of the motor and they look good. I'm not getting an engine light. All of the vacuum lines look to be connected as far as I can tell. It just won't stay started now or idle. What should be my first troubleshooting step from here?
Thanks,
-mark
Mark "Sharky" Stover
73 Century Regal 455
05 Chrysler T&C
07 Dodge Ram SLT
11 GMC Yukon Denali XL
Old 07-10-2011, 09:46 AM
jdl jdl is offline
Re: 2001 1500 dies after warmed up
Clean the throttle body and idle air control.
Old 07-10-2011, 04:38 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I worked on a Camaro that ran good cold but ran poor hot and wouldn't start hot.
The ignition coil was bad....I guess the internal insulation wa breaking down when hot.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-11-2011, 06:21 AM
Thanks.
I saw similar issues with other vehicles on the internet so I got up Sunday morning and pulled the IAC off. It was covered with gunk. After cleaning it up it ran fine all day.
-mark
05 Chrysler T&C
07 Dodge Ram SLT
Old 07-11-2011, 09:21 PM
AF - Advisor
Good work, thanks for the update!
The Following User Says Thank You to Chris Stewart For This Useful Post:
sharkmonkey (07-12-2011)
Old 07-12-2011, 09:56 AM
jdl jdl is offline
Good job.
The Following User Says Thank You to jdl For This Useful Post:
Old 07-12-2011, 10:06 AM
I'm really enjoying this truck (now). It has a ton of miles on it, about 246,000, but seems to run really well. The engine is very smooth. There's no maintenance receipts so I'm not sure what has been done to it so far.
-mark
05 Chrysler T&C
07 Dodge Ram SLT
Old 07-12-2011, 10:11 AM
jdl jdl is offline
The vehicle sounds great, take care of it.
2000 LS2 v6 dies after warm up treblehook LS/LW 9 09-07-2008 07:39 PM
99 camry dies after warmed up? nissandoc Camry/Camry Hybrid/Vista 2 11-10-2006 01:58 PM
1987 camry dies after warming up matik07 Camry/Camry Hybrid/Vista 3 06-26-2006 04:28 AM
89 stalls/dies after warming up wwwildman Cherokee 9 12-27-2005 04:48 PM
91 Transport engine dies after warming up dano10 Trans Sport 1 06-16-2004 07:15 AM
